Eclipse errors
My eclipse creates an error every project that I make. It says
“Program “C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64\cl” not found in PATH”
Does anyone know how to fix this?
I’m not a Windows guy, and I haven’t done FRC programming in a while. That being said, it looks like you’re missing some stuff in your PATH environment variable.
A quick fix to see if this is the problem would be to open up a DOS Command Prompt or Powershell, add
to the PATH environment variable, and then launch Eclipse.
Thanks So Much!
