Eclipse help needed
Just getting strated following the WPILIP example…
We create a new project, Command Based and select the Robot Java Project as stated in the WPILIB…
When we try to create our first subsystem, I cannot locate the folder commands and subsystems… thereofre i cant get to the "new, subsystems or command…
We have the plugins installed and the proper JRE…
Guess i am missing something very silly and cant figure it out…
Does File -> New -> Other… -> WPILib Robot Java Development have the subsystem/command options you’re looking for?
The command and subsystem folders should be in the package explorer view under the name of your project -> src
yes! thank you.
This is what my package explorer look like…
https://goo.gl/photos/ezYrRn6KUNT4JpVC6
i was not seeing the folder as they have in the tutorial… and since i am new with java and s=eclipse, it made me a little nervous.
Is there a way i can have these “others” option available when i select “new” instead?
You can go to Window -> Customize perspective… -> Shortcuts and select the ones you want to show up in the “New” submenu
