EDU won't power up.
Just started fooling around with our EDU bot.
I plug in a 7.2v battery and at that instant the Battery Power and fault status light emit a quick red flash.
Hit the power button… no go.
Any ideas? or should I just call innovation first.
-Nick
Recharge the battery / Check the battery voltage
How long did you hold the power on button? You need to hold it down for a second or so to get it to start up…
You fried the on switch on the eduRobot by hooking up a power supply or something.
Solution: Hold power button on and then as you are holding it plug in the battery. Quick fix. We did it too. :slight_smile:
Thanks,
Ryan Waliany
If problem isn’t the holddown time of the power on button then
Check that there are no shorts from 7.2 or 5 v to gnd on any ports or IO.
The internal current sensor shuts off the EDU upon short detection.
