Robot code says that it successfully deploys however FRCDriverStation says otherwise.
WPILib roboRIO debug output:
********** Robot program starting **********
Unhandled exception: java.lang.ClassNotFoundException: edu.wpi.first.wpiutil.RuntimeLoader
Error at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source): Unhandled exception: java.lang.ClassNotFoundException: edu.wpi.first.wpiutil.RuntimeLoader
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at com.revrobotics.jni.RevJNIWrapper.(RevJNIWrapper.java:42)
at com.revrobotics.CANSparkMaxLowLevel.(CANSparkMaxLowLevel.java:38)
at frc.robot.subsystems.SwerveModule.(SwerveModule.java:81)
at frc.robot.subsystems.Drivetrain.(Drivetrain.java:32)
at frc.robot.RobotContainer.(RobotContainer.java:25)
at frc.robot.Robot.robotInit(Robot.java:13)
at edu.wpi.first.wpilibj.TimedRobot.startCompetition(TimedRobot.java:107)
at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:373)
at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:463)
at frc.robot.Main.main(Main.java:19)
The robot program quit unexpectedly. This is usually due to a code error.
The above stacktrace can help determine where the error occurred.
See https://wpilib.org/stacktrace for more information. -
Warning at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:388): The robot program quit unexpectedly. This is usually due to a code error.
The startCompetition() method (or methods called by it) should have handled the exception above.
Error at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:395): The startCompetition() method (or methods called by it) should have handled the exception above.
Listening for transport dt_socket at address: 8349
