Egg drop help Please..:-)
Posted by Travis Covington.
Student on team #115, MV ROBOTICS, from Monta Vista High School and Hitachi Data Systems - 3com - NASA Ames.
Posted on 4/13/2000 8:35 PM MST
hello everyone
Ive got an assignment for physics and im having a hard time thinking of what to make. I know this is supposed to be for robotics postings but I thought what the heck, a little help couldnt hurt anyone.
Soo…Yes its an egg drop vehicle. But theres a catch. The project is worth 80 or so points. If the egg survives you get 70 points if it breaks you get 35. BUT the thing is for every gram your device ways its minus 1 pt. SOOOO im at a loss for words. I dont know what to do. Oh and one more thing…-50pts for ballons or parachutes. hehe there is also 10+ pts for a report etc.
Can anyone help me
Thank You
Travis Team 115
Posted by Lora Knepper.
Student on team #69, HYPER (Helping Youth Pursue Engineering & Robotics), from Quincy Public Schools and The Gillette Company.
Posted on 4/14/2000 8:08 AM MST
In Reply to: Egg drop help Please…:slight_smile: posted by Travis Covington on 4/13/2000 8:35 PM MST:
Hmmm…I’ll have to think about this one for a bit, though I do know that the RAMBOTS (team 419) did do an egg drop exercise as a pre-season team activity. They should have tons of ideas. Try going to their discussion forum on www.rambots.com, or the chat there too. Knowing those guys, they’d love to share some tips with you. Good Luck!
Lora
Posted by Anton Abaya.
Student on team #419, Rambots, from UMass Boston / BC High and NASA, Mathsoft, Solidworks.
Posted on 4/16/2000 10:48 AM MST
In Reply to: Re: Egg drop help Please…:slight_smile: posted by Lora Knepper on 4/14/2000 8:08 AM MST:
Hello…
our eggdrop was a little simpler. limit was paper and tape and the max dimensions was a 12’ x 12’ x 12’ cube.
some covered the egg tons of paper and tape. it took forever to check if the egg survived or not. but eventually, for some weird reason, that strategy of merely wrapping the egg from all sides…DID NOT WORK. The eggs broke in this manner.
On the other hand, there was one person who made a parachute out of paper. It worked nicely. But the parachute ended up performing like a wing and gently landed the egg far away.
I had a different approach, which worked. I folded paper to imitate springs. I surrounded the part of the egg that I figured would fall first, but i covered the entire egg anyway with them, making sure the egg does not come into contact with the ground at all. And then I took two long pieces of paper and added it for style (they looked like tails). My egg was called the sperminator (resembling a sperm). To say the least it survived.
I’ve heard of another design. It involved making a rocket like structure wherein the rocket drops pointed down. The egg is located at the tail of the rocket. Once the rocket hits the ground, the egg travels down the shaft of the rocket which deaccelerates the egg, but not fast enough to break the egg. The rocket is crushed, but the egg survives… It was a daring attempt that nobody thought would work, but did.
My best suggestion is if time permits, buy three dozen eggs and make an omelet. That or test different design ideas and choose the best one.
Have fun! I love EGG DROPS!
–Anton
Team Leader
Rambots, #419
Posted by Thomas A. Frank.
Engineer on team #121, The Islanders/Rhode Warrior, from Middletown (RI) High School and Naval Undersea Warfare Center.
Posted on 4/14/2000 1:59 PM MST
: Soo…Yes its an egg drop vehicle. But theres a catch. The project is worth 80 or so points. If the egg survives you get 70 points if it breaks you get 35. BUT the thing is for every gram your device ways its minus 1 pt. SOOOO im at a loss for words. I dont know what to do. Oh and one more thing…-50pts for ballons or parachutes. hehe there is also 10+ pts for a report etc.
Hi Travis;
Let’s see if I can offer some advice, as I’ve been there, done that. You didn’t mention the height…in our case, it was out a 7th floor window of the Johnson Engineering Center (RPI) onto the concrete patio below…where a large target was placed. You had to hit it bullseye to have any chance of winning.
We had a 1 kg weight limitation, and the contraption had to fit in a box 10x10x10’ pre-launch (sounds suspiciously like a FIRST project, eh?).
I will say this, the associated rules you describe definitely make it a different contest than when I was doing it! That penalty for weight is nasty, and takes away the usual approach to the problem…which is to float the egg in a container of salt water (such that the egg is neutrally buoyant), so the shock load of the impact is equally distributed across the whole shell of the egg (eggs are amazing strong in compression, if the compression is evenly distributed across the whole shell). I’ve also seen grape jelly and a number of similar substances used (personally, I preferred Caro syrup). Did it four years in a row at college, and never had an egg break…but I wasn’t very good at hitting the bullseye. And the final year I did it, when I thought I had the solution (which amounted to an Egg bazooka, with a rocket shaped thing that extended at launch, and which had an Estes rocket motor so I could accelerate it into the ground to limit cross wind effects…the rules said we couldn’t DEcelerate the egg, nothing about ACcelerating the egg…but they wouldn’t let me light off the rocket…something about the safety of the onlookers…). But I digress.
The next logical thoughts are of course parachutes and balloons…but again, there’s a sever penalty. I wonder what the organizer is looking for? Maybe…
Since accuracy of hitting a target is not mentioned, I would take a piece of urethane packing foam - the very light weight (usually yellow) stuff that you typically find really delicate things (like glassware) packed in (you can buy it at most any sewing store, as padding for chairs and the innards of pillows, or a good camera shop as camera case foam liner), make it the maximum size allowed (if there is no size limitation, about 12’ on a side would do), hollow it out to take the egg, and drop it within this ‘block’. The fellow who did this one year at RPI was most successful in protecting the egg; however, just as he tossed it out the window, a updraft lifted the thing, and it went UP a good 250 feet more, before freefalling back on the other side of the building from where the contest was being held…no points for accuracy, but the egg was fine.
You might also consider a bunch of popsicle sticks forming a box, with the egg supported on rubber bands within the box structure.
I would not be surprised to see negative scores on this one. 70 grams is not a whole lot to play with.
Please let us know the results.
Tom Frank
Posted by Ryan Shanley.   [PICTURE: SAME | NEW | HELP]
Student on team #191, The X-Cats, from Joseph C. Wilson Magnet High School and Xerox.
Posted on 4/16/2000 6:40 PM MST
In Reply to: Re: Egg drop help Please…:slight_smile: posted by Thomas A. Frank on 4/14/2000 1:59 PM MST:
Well, I did something like that as a team-building exercise for our team at the begining of this FIRST year, and my idea, which kept the egg in one piece (and weighed virtually nothing) was to bury the egg in layers of crumpled up paper (newspaper, I think) to cushion the impact. Depending on how high of a drop we’re talking about (mine wasn’t anywhere near seven floors), this could require an awful lot of paper, but since paper weighs so little, this might be worth a try. From what I saw in our team’s activity, keeping in mind the comment on how well eggs absorb compression should do you well.
I’d also love to hear what you pick as the best method, and how it works out.
-Ryan Shanley
Posted by Rick Gibbs.
Engineer on team #145, T-Rx, from Norwich High School, Sherburne-Earlville High School and Procter & Gamble Pharmaceuticals.
Posted on 4/18/2000 8:45 PM MST
IF YOU’RE DROPPING THE EGG ONTO A HARD SURFACE (concrete, etc.), then think of the problem a different way. What materials already exists that are lightweight and prevent things from breaking? Answer: almost any type of packing material - bubble wrap, packing peanuts, crumpled newspaper, air bags, etc. That material has to be lightweight to reduce cost and (most of the time) still protects the package contents. Make a package with another lightweight material (seran wrap, other ideas?) that contains your egg and packing material. Should work.
IF YOU’RE DROPPING THE EGG ONTO A SOFTER SURFACE (lawn, etc.) then you don’t have to use anything, a zero gram solution. It is possible to consistently throw a raw egg over a house without it breaking. I’ve recently demonstrated this to one of our FIRST seniors, throwing it ~50’ high and 50’ of distance (over my house). The trick is, when you throw it you have to put a lot of end over end spin on it. Why does it work? I don’t know, but here’s my educated guess (that’s what engineers do well - make educated guesses). Since the center of gravity of the egg is closer to the round end of the egg, and if the egg is spinning fast enough, then the ‘pointed’ end (the strongest end) of the egg will hit the ground first. There’s more to it than that, but maybe this will spawn some hypothesizing.
Good luck.
Posted by Erin.   [PICTURE: SAME | NEW | HELP]
Student on team #1, The Juggernauts, from Oakland Technical Center-Northeast Campus and 3-Dimensional Services.
Posted on 4/25/2000 7:05 PM MST
maybe I shouldn’t be asking questions but…
what is the report supposed to entail? if you need any further help, email me at ErinLinT1@aol.com, I could ask my instructor for any ideas :slight_smile: he is THE #1 (not only by team number but by teaching method) physics teacher so I am sure he will have some good ideas.
yes, he is mike mcintyre.
-erin
Posted on 5/5/2000 12:12 AM MST
In Reply to: looking to help with the egg posted by Erin on 4/25/2000 7:05 PM MST:
Thanks for the help everyone.
(and sorry for the long message…its good tho)
Our physics classes have finished the eggdrop project and have come through with some record breaking results.
First of all id like to say thank you to everyone for all the advice (i told my whole class to read the postings and they really appreciated all of them)
Although I did not follow through w/ any of the ideas posted, my friends at school and on the team did, and created great vehicles that worked and weighed only 10-15 grams. My approch was to make the vehicle entirely out of 1 single piece of printer paper (5 grams or less) So I started thinking, and came up with something simple…A cone!
—If anyones intrested, this is how I did it —
I made a paper cone about 6 in high out of the corner triangle of the printer paper. With the remaining paper I made a ring type thing that slid over the cone, and acted as a wind break to slow the vehivle down as well as keeping it straight. I then made a small cone out of lightweight foam, about an inch t high, and stuffed it down the cone as well as making a foam stopper for the top of the cone. Finally I put as many lightning holes as you can imagine in the areas of the vehicle that would not be affected by the impact.
TOTAL WEIGHT (w/ out egg): 3.9 Grams
When i weighed it at school I was amazed at how much weight i took off by adding the lightning holes.
The test went well too! the vehicle came straight down about as slow as necsesarry. After the impact the egg was undamaged.
My vehicle at 3.9 grams became the new record in my class as well as in my physics teachers career (10 years)
There were also 2 people who broke the record as well w/ a 5 gram vehicle (also a cone) and an 8.5 gram vehicle (again a cone). And the coolest thing is they were members of our robotics team. Cool HUH?
If any one has questions about our egg drop feel free to ask.
And once again thanks for the help everyone!
Travis Covington
-Happy Physics student
There were 2 other people who broke the record as well w/ a 5 gram vehicle (also a cone) and an 8.5 gram vehicle (again a cone). And the coolest thing is they were members of our robotics team. Cool HUH?
Travis Covington
Posted by Becky Allen.   [PICTURE: SAME | NEW | HELP]
Student on team #16, Baxter Bomb Squad, from Mountain Home High School and Baxter Healthcare.
Posted on 5/14/2000 2:02 PM MST
In Reply to: Egg drop News posted by Travis Covington on 5/5/2000 12:12 AM MST:
Congrats to you and your teammates…
That was an ingenius idea…I would never have thought of that.
Just another practical application of FIRST.
Becky
