Electromechanical Solenoids
When considering methods to push the soccer ball, I thought of using a solenoid. Solenoids come in push or pull formats, and the idea is to use electrical energy to create linear motion (DC motors would create rotational motion). Current would flow through a coil of wire and create a magnetic field to push or pull a ferrous, usually iron, core. They’re used in cars as relays, thermostatic control in refrigeration systems, etc. I thought this would be a relatively efficient method for kicking the ball without using pneumatics, and I want to know if this would be a viable option for the robot.
Thank you in advance for any input.
<R53> Items specifically PROHIBITED from use on the ROBOT include:
A. Electric motors and/or servos different from, or in addition to, those in the KOP, with the exception of those specifically permitted by Rule <R52>.
B. **Electric solenoid actuators **(note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not).
We too were thinking of using this as a method of kicking the balls, however <R53> states:
A. Electric motors and/or servos different from, or in addition to, those in the KOP, with the exception of those specifically permitted by Rule .
B. Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not).
The bold text highlights the use of electric solenoids.
However, there is one way that might be viable, which is if the solenoid is built in house. I am in no way the GDC so you would have to post an official Q&A question, but based off of a ruling made for 272 in 2008, I know that the electromagnet they made on there robot was legal because it was a custom electronic piece made by them.
