Elim Rounds
How is the scoring going to work in the elim rounds . . . are the EPs going to accumulative and then the winner will be simply the team with the most amount of EP’s, or will it be like last here, where each round the team with the most EP’s advances but then those points are disregarded with the next match? Thanks!
From what I read the winner of an elimination match is the alliance that has the highest match score after the 2 elimination matches.
After those two matches are completed, the alliance with the highest combined total score advances to the next round.
That is correct. The “EPs” or Elimination Points are calculated the same way as QPs (winner’s score + 2*loser’s score), and the alliance with the most EPs at the end of two rounds is the winner.
