Emerald boa model...
check it out made it this weekend…any comments /critiques welcome…
http://saliksyed.tripod.com/eboa.htm
Add a slight cellular procedural bump map to the skin so it’ll look more detailed.
Also - maybe smooth out the model a little bit - the folds seem to be a litle too sharp, but then i dont know how exactly emerald boa’s head looks like.
Otherwise - nice work!
yeah…i think the folds are too sharp but see when i render w/ light tracer the folds go away and it looks wierd…
the skin texture btw is just temporary i’ll probly have an actual bitmap instead of a procedural for the skin…
You said you used meta reyes muscle system, does that mean that the skin deforms and such as you bend the snake to make it look like it has muscles underneath?
Yes…but only some muscles…
I’d like to see an animation of it wriggling.
LightTracer looks weird because it only leaves diffuse lighting - you dont see any specular highlights. An easy fix is to add some weak point light in addition to your skylight and then render.
