Hey we are using the andymark Sport Two Motor Gearbox with 2 redline motors and we are looking for Encoder. Andymark on longer have RedLine Encoder Kit any alternative that can handle the speed for the motor. Thanks for the help
If you have space on the shaft, you could use the Lamprey encoder that AM sells
No Current RPM data electrical or mechanical
It kinda depends on your setup if this is viable, but we are using the new Rev Robotics Hex encoder to measure the flywheel speed.
Well the lamprey is designed to go around the output shaft which is spinning slower than the motor so it should be good to go
This is always available as well:
