So i am trying to get these encoders working,
http://www.grayhill.com/web1/images/productimages/opt_encoder_63r.pdf
Connected pin 1(encoder) to DigitalI/O in digital sidecar Pin Signal 1
Connected pin 2(encoder) to DigitalI/O in digital sidecar Pin Power 1
Connected pin 3(encoder) to DigitalI/O in digital sidecar Pin Signal 2
Connected Pin 5(encoder) to DigitalI/O in digital sidecar Pin ground 3
and here is the java code i am using to test
public void disabled(){
Encoder TestEnc = new Encoder(2,1);
TestEnc.reset();
for(;;){
System.out.println(TestEnc.get());
Timer.delay(1);
i just keep getting a 0, no matter how much i rotate the encoder, both directions.
I tested the encoder with an arduino and it seems to work fine.
I switched to another digital sidecar and the problem persists.
any ideas?
cheers
arun
