So I am reading the manual and I don’t know if I am missing something or if I’m actually reading this correctly but…can you really only go outside the frame perimeter 12 inches even in end game?
I don’t ever think that I’ve seen a robot not be able to extend more during the end game.
I would agree yes, but wouldn’t say it’s impossible. I would be surprised about a triple, but also to see teams climbing with a buddy as well, due to the minimal amount of extension out of perimeter.
It was designed to make it more difficult to do this, to encourage more teams to attempt to climb on their own. If you could buddy climb hanging from the center of the Switch, it would make getting the rank point a bit too easy for teams that could do it. Instead, you have to achieve balance with two teams hanging from the bar. You notice that it also makes simple winch mechanisms much more difficult, since you need to stay more or less flat when you climb so you don’t violate the frame perimeter rule. One of the pictured violations in the manual shows a robot with it’s frame oriented vertically and a projection past it as a violation. It will be an interesting year for climbs, to be sure.
Who said you can’t? You could climb center yourself, extend a bar off of each side (or front to back) for two others to grab and climb. DEFINITELY wouldn’t be easy, but I think it could be possible. (Even better if you could figure out how NOT to tilt even if only one climbed)
lets also not forget the LITERAL robo wrangler that the robowranglers did in 2018. it didnt extend to far out. you could probably do something like that
