I was trying to deploy a simple robot code to check If the robotpy on the roborio and computer was working properly, but I got an “error 13”
I tried running as an admin, reinstalling robotpy on the rio, and multiple computers. Same error on both computers.
Does anyone have any idea on how to fix the problem?
Robot Code
#!/usr/bin/env python3 import wpilib import wpilib.drive class ExampleBot(wpilib.IterativeRobot): def robotInit(self): self.motor = wpilib.VictorSP(0) def teleopPeriodic(self): self.motor.set(.5) if __name__ == "__main__": wpilib.run(ExampleBot)
Error Log
PS C:\Users\FIRSTUser\Documents\VScodeC++\Hello> py -3 robot.py deploy 20:22:33:079 INFO : wpilib : WPILib version 2020.1.2.2 20:22:33:079 INFO : wpilib : HAL version 2020.1.2.1 20:22:33:079 WARNING : wpilib : Core component versions are not identical! This is not a supported configuration, and you may run into errors! 20:22:33:079 INFO : wpilib : Running with simulated HAL. 20:22:33:083 INFO : robotpy.installer : Finding robot for team 2081 20:22:34:008 INFO : robotpy.installer : -> Robot is at roboRIO-2081-FRC.local 20:22:34:008 INFO : robotpy.installer : Connecting to robot via SSH at roboRIO-2081-FRC.local 20:22:35:848 INFO : paramiko.transport : Connected (version 2.0, client OpenSSH_7.6) 20:22:35:944 INFO : paramiko.transport : Auth banner: b'NI Linux Real-Time (run mode)\n\nLog in with your NI-Auth credentials.\n\n' 20:22:35:944 INFO : paramiko.transport : Authentication (password) successful! WPILib version on robot is 2020.1.2.2 20:22:36:410 INFO : paramiko.transport.sftp: [chan 1] Opened sftp connection (server version 3) py_new make /home/lvuser\py_new 20:22:36:413 INFO : paramiko.transport.sftp: [chan 1] sftp session closed. Traceback (most recent call last): File "robot.py", line 10, in wpilib.run(ExampleBot) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\wpilib\_impl\main.py", line 186, in run retval = options.cmdobj.run(options, robot_class, **kwargs) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyfrc\mains\cli_deploy.py", line 307, in run controller.sftp(py_tmp_dir, deploy_dir, mkdir=not options.in_place) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\robotpy_installer\sshcontroller.py", line 79, in sftp sftp.mkdir(os.path.join(remote_path, d)) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\paramiko\sftp_client.py", line 460, in mkdir self._request(CMD_MKDIR, path, attr) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\paramiko\sftp_client.py", line 813, in _request return self._read_response(num) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\paramiko\sftp_client.py", line 865, in _read_response self._convert_status(msg) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\paramiko\sftp_client.py", line 896, in _convert_status raise IOError(errno.EACCES, text) PermissionError: [Errno 13] Permission denied PS C:\Users\FIRSTUser\Documents\VScodeC++\Hello> py -3 robot.py deploy 20:24:15:914 INFO : wpilib : WPILib version 2020.1.2.2 20:24:15:915 INFO : wpilib : HAL version 2020.1.2.1 20:24:15:915 WARNING : wpilib : Core component versions are not identical! This is not a supported configuration, and you may run into errors! 20:24:15:915 INFO : wpilib : Running with simulated HAL. 20:24:15:919 INFO : robotpy.installer : Finding robot for team 2081 20:24:16:817 INFO : robotpy.installer : -> Robot is at roboRIO-2081-FRC.local 20:24:16:817 INFO : robotpy.installer : Connecting to robot via SSH at roboRIO-2081-FRC.local 20:24:18:614 INFO : paramiko.transport : Connected (version 2.0, client OpenSSH_7.6) 20:24:18:710 INFO : paramiko.transport : Auth banner: b'NI Linux Real-Time (run mode)\n\nLog in with your NI-Auth credentials.\n\n' 20:24:18:711 INFO : paramiko.transport : Authentication (password) successful! WPILib version on robot is 2020.1.2.2 20:24:19:177 INFO : paramiko.transport.sftp: [chan 1] Opened sftp connection (server version 3) py_new make /home/lvuser\py_new 20:24:19:179 INFO : paramiko.transport.sftp: [chan 1] sftp session closed. Traceback (most recent call last): File "robot.py", line 10, in wpilib.run(aaaaa) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\wpilib\_impl\main.py", line 186, in run retval = options.cmdobj.run(options, robot_class, **kwargs) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\pyfrc\mains\cli_deploy.py", line 307, in run controller.sftp(py_tmp_dir, deploy_dir, mkdir=not options.in_place) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\robotpy_installer\sshcontroller.py", line 79, in sftp sftp.mkdir(os.path.join(remote_path, d)) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\paramiko\sftp_client.py", line 460, in mkdir self._request(CMD_MKDIR, path, attr) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\paramiko\sftp_client.py", line 813, in _request return self._read_response(num) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\paramiko\sftp_client.py", line 865, in _read_response self._convert_status(msg) File "C:\Users\FIRSTUser\AppData\Local\Programs\Python\Python38-32\lib\site-packages\paramiko\sftp_client.py", line 896, in _convert_status raise IOError(errno.EACCES, text) PermissionError: [Errno 13] Permission denied
Thanks in advance for any help.
