The code was working earlier, we are not sure what changed to break things. But I am getting this error:
The error we are getting is ERROR 1 DifferentialDrive... Output not updated often enough. edu.wpi.first.wpilibj.MotorSafety.check(MotorSafety.java:96) Error at edu.wpi.first.wpilibj.MotorSafety.check(MotorSafety.java:96): DifferentialDrive... Output not updated often enough.
Heres the github: https://github.com/PortlandRoboticsTeam/FRC-2021-2022-OFFSEASON.git
Any help would be much appreciated, thanks!
********** Robot program starting **********
NT: server: client CONNECTED: 172.22.11.1 port 64421
Warning 44003 FRC: No robot code is currently running. Driver Station
Warning 1 Loop time of 0.02s overrun
edu.wpi.first.wpilibj.IterativeRobotBase.printLoopOverrunMessage(IterativeRobotBase.java:301)
Warning at edu.wpi.first.wpilibj.IterativeRobotBase.printLoopOverrunMessage(IterativeRobotBase.java:301): Loop time of 0.02s overrun
CommandScheduler loop overrun
Warning 1 Drivetrain.periodic(): 0.000093s
buttons.run(): 0.000289s
TshirtCannon.periodic(): 0.009991s
edu.wpi.first.wpilibj.Tracer.lambda$printEpochs$0(Tracer.java:63)
Warning at edu.wpi.first.wpilibj.Tracer.lambda$printEpochs$0(Tracer.java:63): Drivetrain.periodic(): 0.000093s
Warning 1 SmartDashboard.updateValues(): 0.010757s
disabledInit(): 0.200499s
disablePeriodic(): 0.006735s
robotPeriodic(): 0.317847s
LiveWindow.updateValues(): 0.107086s
Shuffleboard.update(): 0.000555s
Warning at edu.wpi.first.wpilibj.Tracer.lambda$printEpochs$0(Tracer.java:63): SmartDashboard.updateValues(): 0.010757s
Warning 0 [phoenix] Library initialization is complete.
Warning 0 [phoenix-diagnostics] Server 1.8.6 (Jan 8 2021,20:09:49) running on port: 1250
Warning 1 Drivetrain.periodic(): 0.000009s
buttons.run(): 0.000022s
DriveSlide.execute(): 0.031643s
TshirtCannon.periodic(): 0.000013s
Warning at edu.wpi.first.wpilibj.Tracer.lambda$printEpochs$0(Tracer.java:63): Drivetrain.periodic(): 0.000009s
Warning 1 teleopPeriodic(): 0.000581s
SmartDashboard.updateValues(): 0.000090s
robotPeriodic(): 0.048181s
LiveWindow.updateValues(): 0.000785s
Shuffleboard.update(): 0.000309s
Warning at edu.wpi.first.wpilibj.Tracer.lambda$printEpochs$0(Tracer.java:63): teleopPeriodic(): 0.000581s
true
fireing true
Warning 1 ShootTshirt.execute(): 0.000038s
ShootTshirt.initialize(): 0.031328s
Drivetrain.periodic(): 0.000010s
buttons.run(): 0.000025s
DriveSlide.execute(): 0.000315s
ShootTshirt.end(false): 0.009281s
TshirtCannon.periodic(): 0.000012s
SafetyOff.end(true): 0.002857s
Warning at edu.wpi.first.wpilibj.Tracer.lambda$printEpochs$0(Tracer.java:63): ShootTshirt.execute(): 0.000038s
Warning 1 teleopPeriodic(): 0.000145s
SmartDashboard.updateValues(): 0.000046s
robotPeriodic(): 0.066130s
LiveWindow.updateValues(): 0.000882s
Shuffleboard.update(): 0.000225s
Warning at edu.wpi.first.wpilibj.Tracer.lambda$printEpochs$0(Tracer.java:63): teleopPeriodic(): 0.000145s
therminated false
true
fireing true
therminated false
Warning 44000 DS Disable Driver Station
