ERROR  -44019  FRC: The mDNS service is slow to respond. Check firewall settings.  Driver Station
I keep getting this :ERROR  -44019  FRC: The mDNS service is slow to respond. Check firewall settings.  Driver Station here is my code: package frc.robot;
import com.ctre.phoenix.motorcontrol.ControlMode;
import com.ctre.phoenix.motorcontrol.NeutralMode;
//import com.ctre.phoenix.motorcontrol.TalonSRXControlMode;
import com.ctre.phoenix.motorcontrol.can.TalonSRX;
import com.ctre.phoenix.motorcontrol.can.WPI_TalonFX;
import edu.wpi.first.wpilibj.motorcontrol.MotorControllerGroup;
//import edu.wpi.first.wpilibj.motorcontrol.VictorSP;
import edu.wpi.first.wpilibj.Servo;
  • The VM is configured to automatically run this class, and to call the functions corresponding to
  • each mode, as described in the TimedRobot documentation. If you change the name of this class or
  • the package after creating this project, you must also update the build.gradle file in the
  • project.
    • This function is run when the robot is first started up and should be used for any
    • initialization code.
      WPI_TalonFX motorRight1 = new WPI_TalonFX(0);
      WPI_TalonFX motorRight2 = new WPI_TalonFX(1);
      WPI_TalonFX motorRight3 = new WPI_TalonFX(2);
      MotorControllerGroup groupRight = new MotorControllerGroup(motorRight1, motorRight2, motorRight3);
WPI_TalonFX motorLeft1 = new WPI_TalonFX(4);
WPI_TalonFX motorLeft2 = new WPI_TalonFX(3);
WPI_TalonFX motorLeft3 = new WPI_TalonFX(5);
MotorControllerGroup groupLeft = new MotorControllerGroup(motorLeft1, motorLeft2, motorLeft3);
// Store the original servo position in a variable
double originalPosition;
TalonSRX window;
Servo Servo;
//Controller
Joystick gamePad;
@Override
public void robotInit()
window = new TalonSRX(10);
Servo = new Servo(7);
gamePad = new Joystick(0);
originalPosition = Servo.getAngle();
//Inverted setting
groupRight.setInverted(true);
groupLeft.setInverted(false);
motorLeft1.setNeutralMode(NeutralMode.Brake);
motorLeft2.setNeutralMode(NeutralMode.Brake);
motorLeft3.setNeutralMode(NeutralMode.Brake);
motorRight1.setNeutralMode(NeutralMode.Brake);
motorRight2.setNeutralMode(NeutralMode.Brake);
motorRight3.setNeutralMode(NeutralMode.Brake);
@Override
public void robotPeriodic() {}
@Override
public void autonomousInit() {}
@Override
public void autonomousPeriodic() {}
@Override
public void teleopInit() {}
@Override
if(gamePad.getRawButton(5)){
//window.set(ControlMode.PercentOutput, 1.0);
else if (gamePad.getRawButton(6)){
window.set(ControlMode.PercentOutput, -1.0);
else {
window.set(ControlMode.PercentOutput, 0);
if (gamePad.getRawButton(1)) {
// Rotate servo to angle
Servo.setAngle(90.0);
} else {
// Set servo angle to the original position
Servo.setAngle(originalPosition);
// Spin control - using two joysticks
double leftStickY = -gamePad.getRawAxis(4);
double rightStickY = -gamePad.getRawAxis(7);
// check if left joystick is held down and right joystick is up
if (leftStickY < -0.5 && rightStickY > 0.5) {
groupLeft.set(0.5);
groupRight.set(-0.5);
// check if left joystick is up and right joystick is down
else if (leftStickY > 0.5 && rightStickY < -0.5) {
groupLeft.set(-0.5);
groupRight.set(0.5);
} else {
// Drive control - Arcade Drive
double moveSpeed = -leftStickY; // inverted for proper control direction
double turnSpeed = gamePad.getRawAxis(4);
// adjust move speed for better control at lower speeds
moveSpeed = Math.copySign(Math.pow(moveSpeed, 2.0), moveSpeed);
// combine move and turn speeds
double leftSpeed = moveSpeed + turnSpeed;
double rightSpeed = moveSpeed - turnSpeed;
// limit motor speed to maximum allowed value
double maxSpeed = 0.8;
leftSpeed = Math.copySign(Math.min(Math.abs(leftSpeed), maxSpeed), leftSpeed);
rightSpeed = Math.copySign(Math.min(Math.abs(rightSpeed), maxSpeed), rightSpeed);
// set motor speeds
groupLeft.set(leftSpeed);
groupRight.set(rightSpeed);
@Override
public void disabledInit()
groupLeft.stopMotor();
groupRight.stopMotor();
@Override
public void disabledPeriodic() {}
@Override
public void simulationInit() {}
@Override
public void simulationPeriodic() {}
You should probably check that the DriverStation and roboRIO have the same team number. Can you reach the roboRIO Web Dashboad?
I mean stupid question here, but have you checked the firewall settings and either A. Disabled all of them (public, private and domain) or B. Allowed the specific apps needed for FRC comms Wpilib docs for this in windows
Why do you believe your code might be affecting the mDNS service?
