ERROR -44087 CAN: Message not found
Our driver station keeps on giving us “ERROR -44087 CAN: Message not found”. On the bus, we have 4 Talon SRXes, 2 Victor SPXes, a PDP and a PCM. All the devices show up in Phoenix Tuner, and at least the motor controllers and PCM have perfect communications. Is this something I should be concerned about? Is there a way to fix it? Thanks.
Is the firmware updated on Phoenix Tuner for each of the devices you mentioned? If they are updated, it may be a problem with the code. Our team can help with LabView but that is the only language we know.
Ah thanks for the suggestion. I forgot that we switched to using a new PDP, and updating the firmware fixed it. Thanks!
