Error at RobotBase. How Can I Fix It?
Eclipse isn’t showing any errors on the Robot.java but when we try to run the code for he riolog shows this:
âž” Launching «’/usr/local/frc/JRE/bin/java’ ‘-Djava.library.path=/usr/local/frc/lib/’ ‘-jar’ '/home/lvuser/FRCUserProgram.jar’»
********** Robot program starting **********
Error at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:249): ERROR Unhandled exception: java.lang.RuntimeException: Code: -1029. HAL: Resource already allocated at [edu.wpi.first.wpilibj.hal.PWMJNI.initializePWMPort(Native Method), edu.wpi.first.wpilibj.PWM.<init>(PWM.java:61), edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java:24), edu.wpi.first.wpilibj.PWMSpeedController.<init>(PWMSpeedController.java:23), edu.wpi.first.wpilibj.Talon.<init>(Talon.java:36), edu.wpi.first.wpilibj.RobotDrive.<init>(RobotDrive.java:94), org.usfirst.frc.team6620.robot.Robot.robotInit(Robot.java:37), edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:64), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:247)]
WARNING: Robots don’t quit!
—> The startCompetition() method (or methods called by it) should have handled the exception above.
I don’t know what is going wrong and it seems like it has something to do with the base code but I’m not sure. Does anyone know what is happening or how to fix it?
In Robot.java line 37, you allocate a PWM port as a Talon as part of your RobotDrive, that was previously allocated for something else. Each PWM port can only be used once.
