Error Programming with Netbeans to CRio
Our classmate says “limited access” to our local network (radio). I am not sure if this is a problem or not. Whenever we reimage the CRio from our Classmate the error goes away for a little and then comes back.
Also whenever we try to download a program from Netbeans with an Ethernet cable to the CRio from our classmate we get the error
“Host is not on the same subnet as the robot. May not be able to complete all communications with robot.
FTP @10.15.17.2
We have set our subnet on the classmate to 255.0.0.0 but the attempt at downloading says “netmask 255.255.255.255”
Finally our last error occurs right after we reimage the CRio from the classmate. It still proceeds with the previous error but continues on with the error
“Waiting to connect to OTA command server of 10.15.17.2:8001 for past 11s”
the time continues to increase until you manually stop the run from attempting to complete itself.
Any help with any of these problems would be greatly appreciated.
I am receiving the same problem. Any help would be greatly appreciated.
Doesn’t “limited access” just mean that there’s no internet connection?
I’m having the same problem as well, but as said above the limited connectivity is simply that you cannot access the internet. So, the problem lies somewhere else. And with the subnet, one of our mentors looked into it, and reasoned out that the subnet is faulty information, because no matter what you set it to, it displays the same value.
I found the solution to this problem, at least for windows, simply turn off windows firewall, and this deletes the issue.
We fixed our problem by making sure it was not connected to any wireless networks when we tried to download
