However, after running that, we get the error below.
# A fatal error has been detected by the Java Runtime Environment:
# SIGILL (0x4) at pc=0xabad5e18, pid=750, tid=3056575584
# JRE version: Java(TM) SE Runtime Environment (8.0_65-b17) (build 1.8.0_65-b17)
# Java VM: Java HotSpot(TM) Client VM (25.65-b01 mixed mode linux-arm )
# Problematic frame:
# C [libstdc++.so.6+0x6ce18]
# Core dump written. Default location: /home/pi/core or core.750
# An error report file with more information is saved as:
# /home/pi/hs_err_pid750.log
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Aborted (core dumped)
Has anybody encountered this issue yet, and how have you solved it?
We switched to a Raspberry Pi 2, and are now getting a different error stating that jniopencv_core cannot be found when running and deploying the GRIP project. I have followed the steps on the wiki and also read this issue, but to no avail. Has anybody encountered and fixed this?
