Error: Unable to locate 'stdio.h'
I’m trying to compile the default camera code, and getting the following error:
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8520 “main.c” -fo=“main.o” /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8520 “user_SerialDrv.c” -fo=“user_SerialDrv.o” /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
C:\robo-code\alpha\user_SerialDrv.c:30: unable to locate ‘stdio.h’
error 1 spawning C:\mcc18\bin\cpp18
Halting build on first failure as requested.
BUILD FAILED: Mon Feb 07 14:32:47 2005
I’ve set my paths correctly, I’m running v6.62 of MPLAB.
Do you have the newest version of the compiler (2.4) installed?
Ah, that could be it. I’ll check back after trying that.
UPDATE: How do I get it?
It should be on the FIRST website somewhere, or that MPLAB website, but the FTP is down now…
Ah, that could be it.[/quote]
I don’t think stdio.h was included with the 2.2 compiler, so that might be it.
There are other possibilities too, though: Make sure you have C:\MCC18\h listed in the Include Path (INCDIR) on the "General" tab of the Build Options dialog. (Modify as need if you installed the compiler other than in c:\mcc18.) Also make sure your code has #include <stdio.h>, and not #include "stdio.h". Otherwise the preprocessor will only look for the file in the current directory, and not in (INCDIR).
