Error when updating wpilib
I’m running a Mac OS w/ M1 chip and when I try to update my environment to the most recent WPILib version, I keep getting this error:
System.ComponentModel.Win32Exception (2): An error occurred trying to start process '/Users/robotics/wpilib/2023/vscode/Visual Studio Code.app/Contents/Resources/app/bin/code' with working directory '/'. No such file or directory
   at System.Diagnostics.Process.ForkAndExecProcess(ProcessStartInfo startInfo, String resolvedFilename, String[] argv, String[] envp, String cwd, Boolean setCredentials, UInt32 userId, UInt32 groupId, UInt32[] groups, Int32& stdinFd, Int32& stdoutFd, Int32& stderrFd, Boolean usesTerminal, Boolean throwOnNoExec)
   at System.Diagnostics.Process.StartCore(ProcessStartInfo startInfo)
   at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
   at WPILibInstaller.ViewModels.InstallPageViewModel.<>c__DisplayClass46_0.<RunVsCodeExtensionsSetup>b__8() in /Users/runner/work/WPILibInstaller-Avalonia/WPILibInstaller-Avalonia/WPILibInstaller-Avalonia/ViewModels/InstallPageViewModel.cs:line 684
   at System.Threading.Tasks.Task`1.InnerInvoke()
   at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state)
--- End of stack trace from previous location ---
   at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot, Thread threadPoolThread)
   at WPILibInstaller.ViewModels.InstallPageViewModel.RunVsCodeExtensionsSetup() in /Users/runner/work/WPILibInstaller-Avalonia/WPILibInstaller-Avalonia/WPILibInstaller-Avalonia/ViewModels/InstallPageViewModel.cs:line 675
   at WPILibInstaller.ViewModels.InstallPageViewModel.InstallEverything(CancellationToken token) in /Users/runner/work/WPILibInstaller-Avalonia/WPILibInstaller-Avalonia/WPILibInstaller-Avalonia/ViewModels/InstallPageViewModel.cs:line 160
   at WPILibInstaller.ViewModels.InstallPageViewModel.RunInstall() in /Users/runner/work/WPILibInstaller-Avalonia/WPILibInstaller-Avalonia/WPILibInstaller-Avalonia/ViewModels/InstallPageViewModel.cs:line 191
   at WPILibInstaller.ViewModels.InstallPageViewModel.<>c__DisplayClass24_0.<<-ctor>g__installFunc|0>d.MoveNext() in /Users/runner/work/WPILibInstaller-Avalonia/WPILibInstaller-Avalonia/WPILibInstaller-Avalonia/ViewModels/InstallPageViewModel.cs:line 73
This happens when you press the skip button for installing VS Code. You can’t skip that if you haven’t already installed FRC VS Code. Also you can’t move the FRC VS Code app either after installation.
Oh no, so I’m not supposed to move the FRC VS Code app? That probably is why I kept getting the error.
Correct. It depends on the app being in the location it gets installed to.
