I am the programmer from team Yellow Jacket 3345, the driver station is giving me error about the joysticks are not plug in,but ti is plug in right and all show green but we all check the program is no error.And we don’t know the problems.
package org.usfirst.frc.team3345.robot;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Spark;
import edu.wpi.first.wpilibj.Talon;
final String defaultAuto = "Default";
final String customAuto = "My Auto";
String autoSelected;
SendableChooser<String> chooser = new SendableChooser<>();
private RobotDrive robotDrive1, robotDrive2;
private Joystick leftJoystick, rightJoystick;
private Spark gearMotor;
private Talon fuelGate, scissorLift;
private double driveBaseSpeed = 1.0;
private double scissorLiftSpeed = 1.0;
private double fuelGateSpeed = 1.0;
private double gearMotorSpeed = 1.0;
@Override
public void robotInit() {
chooser.addDefault("Default Auto", defaultAuto);
chooser.addObject("My Auto", customAuto);
SmartDashboard.putData("Auto choices", chooser);
//spark and function part
robotDrive1 = new RobotDrive(1, 2);
robotDrive2 = new RobotDrive(3, 4);
fuelGate = new Talon(5);
scissorLift = new Talon(6);
gearMotor = new Spark(0);
leftJoystick = new Joystick(1);
rightJoystick = new Joystick(2);
@Override
autoSelected = chooser.getSelected();
// autoSelected = SmartDashboard.getString("Auto Selector",
// defaultAuto);
System.out.println("Auto selected: " + autoSelected);
@Override
switch (autoSelected) {
case customAuto:
// Put custom auto code here
break;
case defaultAuto:
default:
// Put default auto code here
robotDrive1.arcadeDrive(0.5, 0.0);
robotDrive2.arcadeDrive(0.5, 0.0);
gearMotor.set(0.5);
fuelGate.set(0.5);
scissorLift.set(0.5);
break;
@Override
while(true) {
robotDrive1.arcadeDrive(leftJoystick.getY()*driveBaseSpeed, rightJoystick.getX());
robotDrive2.arcadeDrive(leftJoystick.getY()*driveBaseSpeed, rightJoystick.getX());
gearMotor.set(rightJoystick.getY()*gearMotorSpeed);
if(rightJoystick.getRawButton(4)) {
fuelGate.set(1.0*fuelGateSpeed);
} else if(rightJoystick.getRawButton(5)) {
fuelGate.set(-1*fuelGateSpeed);
} else {
fuelGate.set(0);
if(rightJoystick.getRawButton(6)) {
scissorLift.set(1.0*scissorLiftSpeed);
} else if(rightJoystick.getRawButton(7)) {
scissorLift.set(-1*scissorLiftSpeed);
} else {
scissorLift.set(0);
@Override
public void testPeriodic() {
The joystick are counted from 0, if you look in the SmartDashboard in the USB devices sub-folder, you see that near each joystick there’s a number, that is the number in the constructor for Joystick. So if you plugged 2 joysticks, and they were in the first 2 positions, but in the constructor you put 1 and 2, it will not find a device in port 2, that will give you an error.
Sorry for the long comment, here’s a potato (head).
Are they in port 0 and 1 in the SmartDashboard as we? (Inside the driver station go to USB Devices and check the numbers to the left of the joysticks highlighted green).
