Error with the recent gradle version update
I just went through and imported a 2021 project into 2022, and when I try to build I get this error:
  • Where:
    Build file ‘C:\Users\Eliza\OneDrive\Desktop\2022 Robot\frc-2022\build.gradle’ line: 3
  • What went wrong:
    An exception occurred applying plugin request [id: ‘edu.wpi.first.GradleRIO’, version: ‘2022.2.1’]
Failed to apply plugin [class ‘edu.wpi.first.deployutils.deploy.DeployPlugin’]
Could not create an instance of type edu.wpi.first.deployutils.deploy.DeployExtension.
‘org.gradle.api.ExtensiblePolymorphicDomainObjectContainer org.gradle.api.model.ObjectFactory.polymorphicDomainObjectContainer(java.lang.Class)’
When hovering over the line where the error is I get this:
Could not run phased build action using connection to Gradle distribution ‘https://services.gradle.org/distributions/gradle-6.0.1-bin.zip’.
'org.gradle.api.ExtensiblePolymorphicDomainObjectContainer org.gradle.api.model.ObjectFactory.polymorphicDomainObjectContainer(java.lang.Class)'Java(0)
How did you do the import? You should use the project importer (Importing a Gradle Project — FIRST Robotics Competition documentation) to create a new 2022 project from your 2021 project. You can’t just edit the version number in build.gradle.
That seems to have worked, thank you!
