Error
Hi, I have the following error displayed on the driver station when teleop is enabled:
ERROR: A timeout has been exceeded: RobotDrive...Output not updated often enough. ...in Check() in c:/Windriver/workspace/WPILib/MotorSafetyHelper.cpp at line 123
I am using the SimpleRobot example and I also used the following code as well and received the same result:
#include "WPILib.h"
class Robot : public IterativeRobot
	RobotDrive myRobot;
  	Jaguar ballpicker;
  	Joystick leftStick; // left joystick in USB 1 of the DS
  	Joystick rightStick; // and right JS is in USB 2 of the DS
  	Solenoid sol1;
  	Solenoid sol2;
  	Compressor compress;
  public:
  Robot():
    		myRobot(1,2), // Drive Motors
    		ballpicker(3), // Motor That Picks Up Balls
    		leftStick(1),
    		rightStick(2),
    		sol1(2,1), // MIGHT HAVE TO CHANGE FIRST COORDINATE BECUASE MODULES-
    		sol2(2,2), // HAVE CHANGED THIS YEAR!!!
    		compress(1,1)
   // Any Constructor Code Here...
  		void TeleopInit()
       GetWatchdog().SetEnabled(true);
       compress.Start();
  		void TeleopPeriodic()
    	GetWatchdog().Feed();
    	myRobot.ArcadeDrive(leftStick); // Arcade Style--> Left Stick
    	if (leftStick.GetRawButton(3))
    		ballpicker.Set(0.1); // --> If Button 3-->Input-->10% Power
    	else
    		ballpicker.Set(0.0); // --> If Button 3-->No Input-->No Power
		} // Left Stick Is For Driver/Ball Picker Up'er
    	if(rightStick.GetTrigger()) // Right Stick Is For Shooter
    		sol1.Set(true); // --> If Right Trigger-->Input-->Valve 1-->True
    		sol2.Set(false); // --> Valve 2-->False
    	else
    		sol1.Set(false); // --> If Right Trigger-->No Input-->Valve 1-->False
    		sol2.Set(true); // --> Valve 2-->True
    	Wait(0.005); // --> Allows Time for Motor Refresh/Update
START_ROBOT_CLASS(Robot);
I don’t see any errors in my code and have had it checked by another individual as well.
Please help.
Thank You.
Is the robot working as expected despite the displayed error?
We also have this problem. When we have it all the pwms associated with the RobotDrive are disabled. All others work.
We have used feeding the watchdog as a work around. The MotorSafety true/false has not been a solution. I still cannot directly use those pwms without allocation errors and it does not work in my autonomous section. What we don’t know is why this year’s version of Windriver/robot image cannot use last year’s code on the robot.
