Ethernet port on robot
Which makes sense as we have had unexplained connectivity issues in the past which in turn taught us to mount the radio in more clear spaces.
Our design is very similar to Boom Done with a vertical backplate. The router is to be mounted toward the top of the backplate behind the catapult arm.
Two students are full steam ahead to implement the idea. Engineering mentors have said that this is not necessarily a bad idea. I just am having a hard time seeing it’s purpose in our current design. On some of our other bots, maybe, just not necessarily this year’s bot.
My contention is that you should never plug and unplug the programming computer from the router or cRio when the robot is powered. Period. Turn off the robot, disconnect the battery and then plug and unplug from the router. Or do I not correctly understand how code is uploaded and transferred?
My primary issues were legality (which has been answered here) and whether or not it had been done before.
There’s no need to turn everything off to plug in or unplug a ethernet cable. You can leave the robot running and upload code as many times as you want, you just may need to occasionally reboot the cRio.
The real use for a port like this is for the practice field. If you’re driving the robot around while it’s tethered, or attempting to test autonomous, it’s possible (even likely?) that the ethernet cable will get yanked at some point. Even in your pit, it’s possible for someone to trip over it. When that happens, you don’t want it to break the ports on the router!
If you have sharp pointy things that can poke/scratch hands, they ought to be dealt with. It’s an inspection checklist item and I’m surprised Jon and Al didn’t already make mention of this!
Your electrical team has sensitive hands also, as do your inspectors.
That being said, it still adds convenience for reasons previously covered, and prevents programmers from disrupting things when reaching into the bot, even if those things are now non-pointy.
My apologies, let me clarify; from a safety standpoint I have always told my students that they are not to ever place their hands within the frame of the robot while it is powered up. Let it destroy itself if it goes haywire but not my children’s hands (or other appendages for that matter). And as far as the ‘sharp pointy things’ yes those will be taken care of prior to competition I promise :]
The first year I participated in FIRST a safety incident was posted here on CD regarding a child who lost a finger at another regional because they thought their code had completed its cycle. That may have made me a little paranoid regarding sticking hands and fingers inside the bot while it is powered. Unplugging the battery is just an added precaution that the robot is not going to eat anyone.
I can see the argument for the port on the practice field. Like others we have a Classmate who has a port issue due to a short Ethernet cable. I just had never heard of the pigtails being used.
