Followed instructions on how to create and use GRIP generated pipeline for line detection, then added to lambda below. When running in RoboRio, I get the following error:
Exception in thread “WPILib Vision Thread” java.lang.Exception: std::exception: std::bad_alloc
at org.opencv.imgproc.LineSegmentDetector.detect_1(Native Method)
at org.opencv.imgproc.LineSegmentDetector.detect(Unknown Source)
at org.usfirst.frc.team3577.robot.pipelines.GripPipeline.findLines(GripPipeline.java:217)
at org.usfirst.frc.team3577.robot.pipelines.GripPipeline.process(GripPipeline.java:75)
at edu.wpi.first.wpilibj.vision.VisionRunner.runOnce(VisionRunner.java:90)
at edu.wpi.first.wpilibj.vision.VisionRunner.runForever(VisionRunner.java:111)
at edu.wpi.first.wpilibj.vision.VisionThread$$Lambda$6/8454856.run(Unknown Source)
at java.lang.Thread.run(Thread.java:745)
Any idea what could cause it?
thank you!!
UsbCamera camera = CameraServer.getInstance().startAutomaticCapture();
camera.setResolution(IMG_WIDTH, IMG_HEIGHT);
visionThread = new VisionThread(camera, new GripPipeline(), pipeline -> {
if (!pipeline.findLinesOutput().isEmpty()) {
GripPipeline.Line line = pipeline.findLinesOutput().get(0);
synchronized (imgLock) {
centerX = (line.x1 + line.x2)/2;
centerY = (line.y1 + line.y2)/2;
visionThread.start();
SmartDashboard.putData(drivetrain);
package org.usfirst.frc.teamXXXX.robot.pipelines;
import java.io.File;
import java.io.FileWriter;
import java.io.IOException;
import java.util.ArrayList;
import java.util.List;
import java.util.Map;
import java.util.stream.Collectors;
import java.util.HashMap;
import edu.wpi.first.wpilibj.vision.VisionPipeline;
import org.opencv.core.*;
import org.opencv.core.Core.*;
import org.opencv.features2d.FeatureDetector;
import org.opencv.imgcodecs.Imgcodecs;
import org.opencv.imgproc.*;
import org.opencv.objdetect.*;
* GripPipeline class.
* <p>An OpenCV pipeline generated by GRIP.
* @author GRIP
public class GripPipeline implements VisionPipeline {
//Outputs
private Mat resizeImageOutput = new Mat();
private Mat hsvThresholdOutput = new Mat();
private Mat cvErodeOutput = new Mat();
private Mat maskOutput = new Mat();
private ArrayList<Line> findLinesOutput = new ArrayList<Line>();
static {
System.loadLibrary(Core.NATIVE_LIBRARY_NAME);
* This is the primary method that runs the entire pipeline and updates the outputs.
@Override public void process(Mat source0) {
// Step Resize_Image0:
Mat resizeImageInput = source0;
double resizeImageWidth = 320.0;
double resizeImageHeight = 240.0;
int resizeImageInterpolation = Imgproc.INTER_CUBIC;
resizeImage(resizeImageInput, resizeImageWidth, resizeImageHeight, resizeImageInterpolation, resizeImageOutput);
// Step HSV_Threshold0:
Mat hsvThresholdInput = resizeImageOutput;
double] hsvThresholdHue = {48.561151079136685, 180.0};
double] hsvThresholdSaturation = {48.156474820143885, 255.0};
double] hsvThresholdValue = {149.05575539568346, 255.0};
hsvThreshold(hsvThresholdInput, hsvThresholdHue, hsvThresholdSaturation, hsvThresholdValue, hsvThresholdOutput);
// Step CV_erode0:
Mat cvErodeSrc = hsvThresholdOutput;
Mat cvErodeKernel = new Mat();
Point cvErodeAnchor = new Point(-1, -1);
double cvErodeIterations = 1.0;
int cvErodeBordertype = Core.BORDER_CONSTANT;
Scalar cvErodeBordervalue = new Scalar(-1);
cvErode(cvErodeSrc, cvErodeKernel, cvErodeAnchor, cvErodeIterations, cvErodeBordertype, cvErodeBordervalue, cvErodeOutput);
// Step Mask0:
Mat maskInput = resizeImageOutput;
Mat maskMask = cvErodeOutput;
mask(maskInput, maskMask, maskOutput);
// Step Find_Lines0:
Mat findLinesInput = maskOutput;
findLines(findLinesInput, findLinesOutput);
* This method is a generated getter for the output of a Resize_Image.
* @return Mat output from Resize_Image.
public Mat resizeImageOutput() {
return resizeImageOutput;
* This method is a generated getter for the output of a HSV_Threshold.
* @return Mat output from HSV_Threshold.
public Mat hsvThresholdOutput() {
return hsvThresholdOutput;
* This method is a generated getter for the output of a CV_erode.
* @return Mat output from CV_erode.
public Mat cvErodeOutput() {
return cvErodeOutput;
* This method is a generated getter for the output of a Mask.
* @return Mat output from Mask.
public Mat maskOutput() {
return maskOutput;
* This method is a generated getter for the output of a Find_Lines.
* @return ArrayList<Line> output from Find_Lines.
public ArrayList<Line> findLinesOutput() {
return findLinesOutput;
* Scales and image to an exact size.
* @param input The image on which to perform the Resize.
* @param width The width of the output in pixels.
* @param height The height of the output in pixels.
* @param interpolation The type of interpolation.
* @param output The image in which to store the output.
private void resizeImage(Mat input, double width, double height,
int interpolation, Mat output) {
Imgproc.resize(input, output, new Size(width, height), 0.0, 0.0, interpolation);
* Segment an image based on hue, saturation, and value ranges.
* @param input The image on which to perform the HSL threshold.
* @param hue The min and max hue
* @param sat The min and max saturation
* @param val The min and max value
private void hsvThreshold(Mat input, double] hue, double] sat, double] val,
Mat out) {
Imgproc.cvtColor(input, out, Imgproc.COLOR_BGR2HSV);
Core.inRange(out, new Scalar(hue[0], sat[0], val[0]),
new Scalar(hue[1], sat[1], val[1]), out);
* Expands area of lower value in an image.
* @param src the Image to erode.
* @param kernel the kernel for erosion.
* @param anchor the center of the kernel.
* @param iterations the number of times to perform the erosion.
* @param borderType pixel extrapolation method.
* @param borderValue value to be used for a constant border.
* @param dst Output Image.
private void cvErode(Mat src, Mat kernel, Point anchor, double iterations,
int borderType, Scalar borderValue, Mat dst) {
if (kernel == null) {
kernel = new Mat();
if (anchor == null) {
anchor = new Point(-1,-1);
if (borderValue == null) {
borderValue = new Scalar(-1);
Imgproc.erode(src, dst, kernel, anchor, (int)iterations, borderType, borderValue);
* Filter out an area of an image using a binary mask.
* @param input The image on which the mask filters.
* @param mask The binary image that is used to filter.
private void mask(Mat input, Mat mask, Mat output) {
mask.convertTo(mask, CvType.CV_8UC1);
Core.bitwise_xor(output, output, output);
input.copyTo(output, mask);
public static class Line {
public final double x1, y1, x2, y2;
public Line(double x1, double y1, double x2, double y2) {
this.x1 = x1;
this.y1 = y1;
this.x2 = x2;
this.y2 = y2;
public double lengthSquared() {
return Math.pow(x2 - x1, 2) + Math.pow(y2 - y1, 2);
public double length() {
return Math.sqrt(lengthSquared());
public double angle() {
return Math.toDegrees(Math.atan2(y2 - y1, x2 - x1));
* Finds all line segments in an image.
* @param input The image on which to perform the find lines.
* @param lineList The output where the lines are stored.
private void findLines(Mat input, ArrayList<Line> lineList) {
final LineSegmentDetector lsd = Imgproc.createLineSegmentDetector();
final Mat lines = new Mat();
lineList.clear();
if (input.channels() == 1) {
lsd.detect(input, lines);
} else {
final Mat tmp = new Mat();
Imgproc.cvtColor(input, tmp, Imgproc.COLOR_BGR2GRAY);
lsd.detect(tmp, lines);
if (!lines.empty()) {
for (int i = 0; i < lines.rows(); i++) {
lineList.add(new Line(lines.get(i, 0)[0], lines.get(i, 0)[1],
lines.get(i, 0)[2], lines.get(i, 0)[3]));
