Hey all, we are using some form of trajectory following this year (most likely path planner Introducing PathPlanner 2.0 ) and we are trying to build our 1\2\4\5 ball auto. With these tools the path planning is easy. Integration into your robot workflow seems to be a little more difficult.
As it stands today we are time-stamping the data and choosing to intake or shoot at set timestamps (after all trajectory following is timestamp-based anyway)
But this seems fishy, and annoying to adjust if we change the speed \ acceleration of the trajectory.
Using a command group, run the trajectory in a command parallel to the series of other commands you want to execute. Add a timeout to each of the other commands so they start or stop at the specified times.
Does anyone know if a trajectory can end with a non-zero velocity? That might provide alternative solutions as well.
I believe that would happen regardless of what method you use if you used time stamping.
I was hoping to find a way to start/end a (WPILIB) trajectory at a non-zero speed. That way, you could make the command waypoint dependent. I don’t currently see a way to do that however.
Yes definitely, and this is a great idea… I’m afraid of the plethora of possibilities that I miss the cargo or something gets stuck in our indexer.
You could try computing the distance between a desired waypoint/Pose2d location and your current odometer. If the distance is below a certain value, trigger your “at waypoint” code.
You would probably want a “NEAR WAYPOINT” variable (within some tolerance) from the trajectory library.
I think you’re on top something! Thanks for spelling this out, perhaps others have been saying this as well, but what clicked for me is doing this by distance traveled from waypoint to way point!
Just be careful about the “nearWaypoint” test. If I understand it correctly, the path following does not need to actually go through the waypoints. So, you risk having the robot drive past the point at a distance larger than you threshold, and it will never trigger.
A safer, but distinctly more complicated, test would be look for getting closer to the waypoint and then further away. Once it is definitely getting farther from the waypoint, you know to start the command.
OTOH, maybe the path is more reliable and does not need to be that complicated. Your call.
After some deliberation, we decided to use @veg 's response as a basis for our “path listener”. Although, we may never actually hit the waypoint, the distance between the two waypoints should be really close to reality (we’re not using distance traveled–strictly as the crow flies distance)
This is a good backup plan if our initial plan doesn’t work.
