We debated a lot about what drive-train material to use because pre-patterned box tubing is great, making it much faster to build things. We eventually ended up having a sponsor pattern 1/8 box tubing because we felt that it wasn’t worth the risk to be running thin tubing, and we needed the lower CG anyway.
I wish the scribe lines didn’t exist for the grid pattern, they aren’t that necessary when you already have the holes from the hole pattern, and they look kind of ugly. Also, thickening up the 0.04 side would be nice.
Another thing is that it would be nice if REV could sell a jig or something for marking box tube to cut to length, I know teams have their own solutions, but a COTS solution you know will work is nice.
Maxplanetaries seem to be okay, we ended up having some weird shearing issues (there suddenly was a lot of metal shavings in the MP and it stopped working) in one of our MAXplanetaries (noncantilever steel shaft, arm gearbox with large chain reduction to protect) We aren’t really sure where it came from, but we replaced the gearbox stage and CIM key, and it seemed to be ok.
The CAD is kind of unoptimized though… there are so many unnecessary parts that hurt your load times for no reason, plz simplified the version.
We found the absolute encoder adapter was hard to use, so we ended up not using it and going straight to DIO.
Tube plugs work, we have some issues with cross-threading the screws, but that’s a skill issue on our part I think.
Maxspline: The bracket plates seemed to have issues with fitting with the spline shaft. Otherwise, it seemed to work well and was compatible with the stepped bushings and 3/4 tube included without not too many issues.
Overall, it improved our workflow and speed a lot, so it works.
