Extending power wires on POE cable
Can the power cables be extended on the orange POE cable? They will properly be cut and solder extended with the proper gauge wire and terminated with ferule connectors back to the PDP. Just wondering if this will cause us a hard time with tech inspection or reliability issues. This cable will power a Limelight.
What we do is use a female to male Ethernet to connect our limelight from the POE cable. To answer your question - there shouldn’t be an issue extending the power terminals, as long as you do it properly with shrink wrap and all :slight_smile:
