Failed to attach to remote debuggee VM. Reason: java.net.ConnectException: Connection refused
Hello! we get the error “Failed to attach to remote debuggee VM. Reason: java.net.ConnectException: Connection refused” whenever we try to debug in the VSCode application. It only works from time to time, and we haven’t found a pattern to it yet. We are wondering if anyone has also come across this issue and if anyone has found a way to fix it or at least found a reliable way to use the debugger without using the simulator. Thank you!
