Failed to connect to target Error
Hey we are using windriver and after we set up the environment the robot failed to connect to the crio. We have reimaged the crio for windriver correctly with the correct driverstation update. We are just not sure what went wrong.
Doc1.doc (46 KB)
Doc1.doc (46 KB)
Looks like you have the IP address set to 10.8.43.2. If you are following the documented network conventions, you should be trying to connect to 10.8.42.2
its a practice bot so we changed everything to 843.
Is everything set to 10.08.43.* (router, cRio, wireless bridge, driver station, laptop from which you are running code)? If not, the cRio won’t be able to connect to the router. Also, make sure each device has the correct last digit. I think the radio is .1, the router is .4, the cRio is .2, the DS is .5, etc., but you should check. It can be found in the Control System Manual, Chapter 2. You may as well check that you have all the updates too.
Even if everything is 10.08.43., I can’t guarantee it will work (anyone know more about this?). You might as well change back to 10.08.42. so that it’s ready for use in competition, especially since it’s unlikely you will have both systems running at the same time.
It is likely because we practice with offense and defense but we are able to connect on the driver station and are able to ping the crio.
