Hello,
Currently, I’m trying to do a simple DriveStraight program, and I basically copied this example program but using 4 motors (adding 2 followers) rather than 2: https://github.com/CrossTheRoadElec/Phoenix-Examples-Languages/blob/master/Java%20Talon%20FX%20(Falcon%20500)/DriveStraight_AuxIntegratedSensor/src/main/java/frc/robot/Robot.java.
However, as I try to run the code, there seemed to be a clicking noise — upon further investigation through SmartDashboard outputs, it seems that the follower motors have a smaller motor output than the master masters for a split second before they catch up. This may correlate with the clicking sounds (will post video once I have access to robot) - not sure if this is due to some kind of delay or anything. I’m thinking that my configuration went wrong somewhere; here’s my code:
LINK MIX: 2 URLs are contained (using this since new users can’t put more than 2 links in a post
It’s also interesting to note that teleop seems to work fine in which we’re using arcade drive through DifferentialDrive. Has anyone run into a similar issue? Did I do something wrong in configuring the followers?
Lemme know if you need any moire info, and thanks in advance :).
