So my team recently went through the process of upgrading a bunch of our falcon 500 motors when on the last motor we realized we had somehow lost the end cap bearing in the process. We’ve looked for a little bit online and can’t seem to find both the specifications of the actual bearing and where to buy a replacement. We’re awaiting a response from VEX but in the meantime is this a part we can replace or do we just use this falcon as a spare? Thanks!
We ended up losing one of those bearings in the process of changing the falcon shaft to a cim shaft and picked up MR148ZZ bearings. You can find them on amazon, ebay, etc. Haven’t tested the motor extensively but all the dimensions seemed to line up and it spun smoothly again.
OK,
When I hear about modifications to a non-modify item, I have to ask. Don’t use the motor without the bearing, it will likely damage the innards of the motor (rotor). VEX is good about supporting their products. I am sure they will respond.
