Falcon 500
Does the falcon 500 work with a vexplanetary cim adapter?
A) wrong category, probably should go in technical
B) probably not, although without knowing the kit I can’t say if you could make it work. F500 does not have the same keyed shaft interface as a cim.
Yes it works, but you need the VP output and they are hard to come by. With some clever machining or additive manufacturing you might be able to make a solution that works.
We are currently using on through a VP CIM adapter on our launcher.
Another option would be to purchase the 8mm Keyed Output Shaft from ThriftyBot.
Then you can just cut the shaft to length and mount the VP to a Falcon just as you would mount it to a CIM.
