Falcon Encoder Issue
How do you code the encoders on the Falcon 500? My team followed the CANcoder documentation but it still returns a value of 0.
EDIT: We are now getting an error message
“ERROR -3 CTR: CAN frame not received/too-stale. CANCoder 1 GetPosition”
The encoders on the Falcon’s are not CANcoders. Use it as you would get an encoder value from a TalonSRX. i.e. use getSelectedSensorPosition()
thank you :slight_smile:
Any chance you could share your code or direct me to your site? We just got Falcons this year and we are very inexperienced at PID control.
I would recommend reading the documentation regarding closed loop control with Talons (this applies to both TalonSRX and TalonFX).
https://phoenix-documentation.readthedocs.io/en/latest/ch16_ClosedLoop.html
And using the examples that are available in the example repository.
Thanks! Thats the clarification I was looking for as to how to treat these motors.
One more clarifying question, we define these using WPI_TalonFX - correct?
You can use either WPI_TalonFX or TalonFX. The WPI_ prefix allows you to use WPI classes such as DifferentialDrive with them. You can read up on it here.
https://phoenix-documentation.readthedocs.io/en/latest/ch15_WPIDrive.html
Most examples use the non-WPI version. For an example that does, look at Differential Drive.
