Just getting this going so that we know what’s commonly asked and likely to go to the Q&A if it isn’t answered in an update. I thought of putting it in Rules/Strategy, but decided more visibility is better.
Launching minibots–is it legal under a) free flight or b) tethered to the pole?
Minibots at the top of the pole: Do they have to stay there until after the match, or can they slide down during the match to make retrieval easier?
Are you allowed to move your own tubes, other than ubertubes, around after they are in scoring position?
a)/b) im not exactly sure what you’re asking but i do know that the minibots can be launched, they always have to touch the pole, and once they cross the deployment line you cannot touch them (if thats what you mean by tethered)
No they do not, as long as they hit the pressure-like sensor (2-4 newtons of force btw)
As far as i know, you are allowed to. although you really shouldnt have to :yikes:
It looked like the presentation said the minibot had to climb the pole and trigger the AB stacked signal light. At match end you can look at the field look at the lights. Blinking - no score. Solid - score.
Where is the bumper zone?
(I went to go double check that I knew the bumper zone today and could not find the rule stating it. There are tons of rules about the bumpers, but nothing about exactly WHERE the zone is )
This has been answered, the rule was just hiding in section one instead of section four with the rest of the robot rules
How do coopertition points affect your qualifying and ranking scores?
(There was a clause about how if you loan a minibot to another team, you get a CP, but nowhere did it say how this would affect your ranking or anything at all.)
Is it legal to program your minibot to go up the pole, wait for some time, then be programmed to go back down the pole for easy retrieval?
(Minibots are not controlled by the FMS system, so I’m wondering if programming them to go back down the pole would make it easier to remove them at the end of the match.)
Another for the Q&A:
{RE} <R92> The following items are the only permitted materials for use on the MINIBOTS:
C. exactly one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057)
E. No more than one NXT controller with the Bluetooth functionality disabled,
QUESTION: How are we supposed to power the NXT controller without using its self-contained batery(ies)?
These are basically the three questions my team had that we were waiting to post to the Q&A - since I know they’re common questions that are going to be posted, I’ll pass that on.
They’re ‘analysts.’ From section 1.6 of the game manual: “ANALYST – a HUMAN PLAYER that assists the COACHES with strategy. There is one ANALYST per ALLIANCE.”
My take on the minibots question is that a robot can just deploy one. It refers to minibots in the game manual as ‘the minibot,’ as in, “The ROBOT includes both the HOSTBOT and the MINIBOT (ROBOT = HOSTBOT + MINIBOT).” (From the definition of Robot in section 1.6) That’s not a definitive answer by any means, just an interpretation of the text.
I know this was probably in the manual, but how many tubes do the human players start with to hand to the robots through the slots? This just affects the importance of picking tubes up off the ground.
You get enough logo pieces to fill both scoring grids with logos
6 triangles
6 squares
6 circles
Each feeding station gets 3 sets of logos.
3.1.2 <G10> Each FEEDER STATION must contain 3 sets of LOGO PIECES.
I assess this as, its rather difficult to prevent an opposing alliance from completing at least one logo because that’s taking 6 pieces and putting it possibly into your lane or in your scoring zone.
No game pieces except the uber tubes are on the field before the human players place the logo pieces in the arena in tele-op.
<G02>At 10 seconds before the end of the MATCH, when HOSTBOTS may DEPLOY their MINIBOT without penalty, BASES will illuminate with the appropriate ALLIANCE color, while TARGET lights will show a green ‘chase’ sequence. This chase sequence will continue until a MINIBOT TRIGGERS the TARGET, or time expires, whichever comes first.
So from 2:05 to 2:15 (or the last ten secs of the match) the minibot has that allotted time to get up the pole. It must trigger before the timer is 0.
Also worth noting:
The MATCH ends if all TOWERS are TRIGGERED or when the ARENA timer displays zero seconds, whichever comes first.
A question for the Q&A is:
How will the field management disable the minibot after the match has ended?
To continue on this thread…
<R03> Custom circuits and COTS electronics are expressly prohibited if they:
A. Interfere with the operation of other ROBOTS. B. Directly affect any output devices on the ROBOT.
ROBOT – … ROBOT = HOSTBOT + MINIBOT
What (if there exists) requirements are there for the electrical (power and signal) systems of the MINIBOT?
i.e.
Is it legal to have a the required 12V FTC Battery on the MINIBOT, directly wired through switches to power wheels to CLIMB? (Assume not, for now)
If not, what requirements do we follow for power and signal distribution as the Power and Signal Distribution Diagrams can not obviously be followed for the MINIBOT.
How high are the different levels of the scoring rack?
i looked through the manual and technical drawings but could not find a specific number. thanks in advance
HPs: There are 3 HPs per alliance. One Analyst and 2 Feeders. <G08>.
The reason for the minibot moving upwards is that any scores within 10 seconds after the end of the match count as scored–but does that also apply to Minibots that are obviously on their way up?
Different level heights can be answered once somebody gets their hands on the field drawings.
So, here is the condensed list:
Minibots at the top of the pole: Do they have to stay there until after the match, or can they slide down during/after the match under their own power or via gravity to make retrieval easier?
If a minibot is moving upwards at the end of a match, does it still get the 10 seconds to finish for points?
How many minibots can one hostbot deploy?
NXT power, if used–is there some form of schematic or something?
What methods are acceptable for removing the Minibot from the post? For example, could it drive itself down autonomously? Could someone bring a long pole out and activate something on the robot to make it come down?
For determination of “above the line” during deployment, is the top of the Minibot supposed to be below the line, or just the hostbot device?
8a) Are hostbots allowed to push the minibots upwards or towards the post, provided that this is done below the deployment line?
Could you also add to the list what would be considered “acceptable” methods of removing a minibot from the tower? Ex: Would it be legal to bring an 8 ft pole onto the field to flip a switch on the minibot? (yeah, it’s an extreme situation, but just an example)
