Feedforward calculations using WPILIB updates
With the new WPILIB update they’ve changed how feed forward values are returned. Prior to this update we used this
however this method is going to be removed and several other methods have taken its place. I wanted to know which of the methods below would move an elevator to a setpoint fastest. Any help is greatly appreciated!
Use ElevatorFeedforward.calculateWithVelocities(double currentVelocity, double nextVelocity) with a motion profile.
package frc.robot;
import edu.wpi.first.math.controller.PIDController;
import edu.wpi.first.math.controller.ElevatorFeedforward;
import edu.wpi.first.math.trajectory.ExponentialProfile;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.motorcontrol.PWMSparkMax;
  public static final double dt = 0.01;
  public static final double offset = 0.005;
  public static final double Ks = 0.1;
  public static final double Kg = 4.9;
  public static final double Kv = 3.0;
  public static final double Ka = 0.5;
  public static final double Kp = 0.1;
  public static final double Kd = 0.1;
  public Encoder encoder = new Encoder(0, 1);
  public PWMSparkMax motor = new PWMSparkMax(0);
  public ExponentialProfile profile =
      new ExponentialProfile(ExponentialProfile.Constraints.fromCharacteristics(10.0, Kv, Ka));
  public ElevatorFeedforward feedforward = new ElevatorFeedforward(Ks, Kg, Kv, Ka, dt);
  public PIDController feedback = new PIDController(Kp, 0.0, Kd, dt);
  public ExponentialProfile.State currentSetpoint = new ExponentialProfile.State();
  public ExponentialProfile.State goal = new ExponentialProfile.State();
  public Robot() {
    addPeriodic(this::controller, dt, offset);
  public void setGoal(double goal) {
    this.goal.position = goal;
  public void controller() {
    if (isDisabled()) {
      return;
    var nextSetpoint = profile.calculate(dt, currentSetpoint, goal);
    motor.setVoltage(
        feedforward.calculateWithVelocities(currentSetpoint.velocity, nextSetpoint.velocity)
            + feedback.calculate(encoder.getDistance(), currentSetpoint.position));
    currentSetpoint = nextSetpoint;
