I’d be willing to bet that you’re right.
Falcon…4334…972. …115
OrangeJuice…2468…2403…2478
FIRST Pick…1477 …3166. …2993
The ULCAN…3230…3241… .3288
Rotten Fruit Alliance…744…3245… 2594
Koko’s X-Cats…6210…4083… .5974
Broconnor…4158…1622 …5869
Bobo Brigade…2465…2484…3289
Swamp Life…329 …3008 … 4348
The Breakfast Company…3374…5489…4944
TEAMS: 1891
3006
3021 3225 3239
3243 3251
4268 4310 4585 4598
5071 5159 5933
Lists From: Rotten Fruit Alliance OrangeJuice Falcon
NO SHOWS:
Alright, this draft got out of hand.
First off, Ed, I appreciate the time you took to run the draft, but we established a set of standards to use the lists that are located at firstinspires. It’s inconvenienced everyone in the league. In the face of an established standard, I’m not sure why you would list 329, and then continue the draft with them.
Furthermore, it’s been made apparent that many teams were either given randoms before their time slot or lists were completely ignored and given randoms. I’m not sure I follow the logic behind this, but it’s nonsensical.
RFA requests a redraft with the correct lists and the proper drafting procedure.
- Sunny G.
As much as I like the picks I got, and appreciate the time and effort you put in Ed, I second this.
As for the date to rerun it on, I have my schedule open for the rest of the draft schedule, so I wouldn’t mind running it, would just need a day or two to get acquainted with the software.
If there is a redraft, I will not be doing it.
In fact I am seriously considering not doing any ore draft or Fantasy FIRST any longer.
I got better things to do.
Falcon assumed that the teams posted were pulled from the proper source list.
Or whoever’s updating forgot to add/remove on the appropriate sites again…
I believe that there are enough problems to warrant a redraft, as requested.
Per standard redraft procedure, once scheduled, the redraft will proceed starting at the first affected pick. Presumably, that would be no earlier than the third pick of the draft (as the first two players both had the affected team on their list, and neither used it). All lists and live picks will be used (where possible). Same order, all that fun stuff.
As far as timing, may I suggest on Sunday, 12/13? That’s the first open point in the schedule, and I may have to move another draft in there anyways.
I’d be fine running it then at standard timing, I would however need the lists sent to me.
Once you are confirmed the draft runner we will re-send the list.
I’ll run it, no issue with any date.
