[FF]: 2017 Israel DCMP
Times will be enforced on 3/27. Please make picks before then.
Swamp Life                     1574    8:07    8:08
The Regal Falcons              7:05    8:04    8:09
Questionable Decisionmakers    7:10    8:01    8:10
Falcon                         7:15    7:58    8:11
FIRST Pick                     7:20    7:55    8:12
NE Way You Want It             7:25    7:52    8:13
Untitled Team                  7:30    7:49    8:14
The Breakfast Company          7:35    7:46    8:15
F3                             7:40    7:43    8:16
1577    1657    1690    1937    1942    1943    2096
2212    2230    2231    2679    3034    3075    3083    3211
3316    3339    3388    3835    4320    4338    4586    4590
4744    5038    5291    5554    5614    5635    5654    5747
5928    5951    5987    5990    6104    6736    6738    6740
6741
TRF would like 1690.
Reminder that TODAY is draft day, and randoms will be assigned for missed picks.
The Regal Falcons              1690    8:04    8:09
F3                             7:40    7:43    8:16
1577    1657    1937    1942    1943    2096
6741
Lists from: Swamp Life, F3
Questionable Decisionmakers select the same team we did for the District draft, 3211.
In other news, QD picked a team responsible for changing a questionable decision. No more 3-2-1-1 when the numbers are being called by the MC!
Questionable Decisionmakers    3211    8:01    8:10
Falcon                         1577    7:58    8:11
F3                             7:40    7:43    8:16
6741
Lists from: Swamp Life, F3, NE WYWI
I’ve been called away by a different volunteering gig. I’ll be back as quickly as I can reasonably be.
Any picks made in my absence will count if they don’t go against any list picks, otherwise a second pick will need to be made. When I return I’ll catch the draft up and restart the pick clock.
If someone wants to pick up the draft, I will be able to respond to PMs/emails, and will send the Excel.
We’re back on. I found FIRST Pick’s list in my PMs, and that’ll bring up Untitled.
All times adjusted by 2:05.
FIRST Pick                     3339    7:55    8:12
NE Way You Want It             2230    7:52    8:13
F3                             7:40    7:43    8:16
2212    2231    2679    3034    3075    3083
3316    3388    3835    4320    4338    4586    4590
6741
Lists from: Swamp Life, F3, NE WYWI, FIRST Pick
4320 for Untitled, please
TBC on the clock–and stand by for a quick turnaround after the pick is up.
Untitled Team                  4320    7:49    8:14
The Breakfast Company          3034    7:46    8:15
F3                             4590    3316    8:16
2212    2231    2679    3075    3083
3388    3835    4338    4586
6741
MIA: TBC
4590
Recheck the picks… taken by F3.
2231, please
Missed by 1 minute :confused:
4338 and 5038
QD on the clock.
Falcon                         1577    6738    8:11
FIRST Pick                     3339    1937    8:12
Untitled Team                  4320    2231    8:14
The Breakfast Company          4338    5038    8:15
F3                             4590    3316    8:16
1657    1942    1943    2096
2212    2679    3034    3075    3083
3388    3835    4586
4744    5291    5554    5614    5635    5654    5747
5928    5951    5987    5990    6104    6736    6740
6741
Does NEWYWI not get a second team?
Had 'em on the sheet, didn’t finish the transfer properly.
QD on the clock.
NE Way You Want It             2230    1657    8:13
F3                             4590    3316    8:16
1942    1943    2096
3388    3835    4586
6741
QD would like to select 2096.
QD on the clock.
Swamp Life                     1574    5614    5291
The Regal Falcons              1690    3034    5747
Questionable Decisionmakers    3211    2096    8:10
F3                             4590    3316    8:16
1942    1943
2212    2679    3075    3083
3388    3835    4586
4744    5554    5635    5654
6741
QD would like to round off our Israel alliance with 5951.
Untitled on the clock.
Questionable Decisionmakers    3211    2096    5951
Falcon                         1577    6738    3083
FIRST Pick                     3339    1937    6740
NE Way You Want It             2230    1657    1943
F3                             4590    3316    8:16
1942
2212    2679    3075
3388    3835    4586
4744    5554    5635    5654
5928    5987    5990    6104    6736
6741
