[FF]: FF Draft Assistant Rewrite
After having some trouble with the installer and less time to work on this than I would have liked I finally have a version of this program ready to test (I think).
The program is posted here as FF_Draft_Assistant_setup.zip
Unfortunately the way it is currently written it is incompatible with both tier files and list files from the previous version.
I couldn’t come up with a good way to parse the list files if the player names have spaces. Right now the program uses list files where the player names are followed by periods. I could switch back to no spaces in player names and no required periods in the list files if that seems like it would be easier.
There’s a brief ReadMe and an example list file included in the install. Feel free to post or PM with any questions or anything that’s broken.
I don’t think the player coloring is explained in the ReadMe yet. Players in green have teams left on their list, players in red do not.
Known Issue: Player coloring does not occur when changing to a new tier for the first time.
Guess I better get testing before too long…
When life is a little less crazy, of course (getting ready to go back to college and all that).
BTW, hitting “apply” with not all the lists in/files loaded simply exits the program with no warning.
Forgot about that one. I did discover that at some point, I’ll add graceful error handling to the list of things to work on.
That problem is now solved (although I haven’t put the new copy up yet). I have also fixed the list coloring and another error I discovered where odd things happened if you selected a time like you were making a manual pick, but then didn’t change the text in the box.
These are all minor edits so I’ll hold onto the new version for now.
There are still issues (crashes or lockups) if you accidentally load a file of the wrong format. I’m going to try to work on that a little bit, but it’s not quite as easy to solve as the other issues were.
A new version has now been posted.
Changes:
New Features:
  1. Auto team list downloading and processing is now available, simply enter the event code in the box.
Error Fixes:
  1. Graceful handling of missing player file or team file.
  2. Player coloring based on list status is available immediately on tab change
  3. Fixed glitch which occurred when selecting a time but making no pick.
I haven’t had a chance to test what happens if you try to use this installer directly over the last install, so there a few ways to upgrade:
  1. Uninstall the old version and install this one
  2. Guinea pig installing this over the other one (I think this will work if you say yes to any file overwrites it asks about)
  3. Download the 4th file listed in the paper and replace your current program with the new one and copy curl.exe into “Install Directory\GTK\bin”
Well, I discovered how to lock up the old version.
Manually enter the team list.
I haven’t tried event code hunting yet; I also can’t figure out how to actually run a draft instead of just set one up.
Guess I better see if the newer version works on that front…
Oh, and when I uninstalled in preparation to install the new one, all the .txt files on my desktop vanished entirely. Ditto for some movies and the .exe files for some other programs that I’d written.
OK, new version: I go to put in a file for players with the requested parameters. It can’t open (but goes right back to the setup screen, which is good). Check the file again, save it again, try again. Then it pops up the manual team entry list box, so I enter that again, then I get an error message “encountered a problem and needs to close. Sorry…”
However, it did spit out the files needed for a draft.
And I figured out how to run it. Next up: testing with lists when I get the time. (Oh, and the manual team entry popped up again when I went to run the draft.)
Well that sounds fun!
I will fix the uninstall problem, I know what caused that.
If you could email me the files you have been using (player and team list) that have been giving you trouble I’ll try to figure out what’s going on. My email is my CD Username @ gmail.com
I’m hoping to get in some more testing of my own tonight as I have been primarily testing all versions with a single player file and team file that haven’t caused these issues.
I got a clean run using the files that I sent and a lists file (after I put the periods in the list file). Can’t wait to get some team lists for the actual events and try it out that way…
It will actually currently pull up the teamlists from this past year’s events when using the automatic download.
The event codes are the same as those listed at frclinks.com
I just fixed it so that it will not try to download a teamlist if the box is left blank. While the download attempt was harmless it set a flag to randomize the teams which may potentially be unwanted behavior.
I am also working on handling some additional errors (such as non-numerical characters in a teamlist) and displaying appropriate error dialogs to explain what’s going on.
Crashed it by putting in a good pick list set… Reopened the program and it worked fine.
I think it doesn’t like if a needed file is modified while the program is open. I don’t know if there is anything that can be done about that, though.
Also, a note: If you’re generating a fresh draft setup, it’s a good idea to remove old tiers–it’ll pick them up as good ones if they’re still around. (Saw that just now, going from my test draft (4 tiers) to AZ (2 tiers)–tiers 1 and 2 changed to AZ tiers, tiers 3 and 4 stuck around and were opened up when I started the program.)
This appears to be the case with many or all of the files that the program opens. I have tried some things that I thought would fix this, but I haven’t managed to knock this one out yet. For now I am modifying error dialogs to recommend restarting the program where appropriate.
If there is an error with the manual teamlist it can be edited and retried because the dialog box closes. I will probably implement a button or menu option to load lists in addition to the automatic prompt so that list files can be fixed without restarting the program.
This confused the heck out of me yesterday, but I forgot to post about it. I spent a long time trying to figure out why the right number of tiers were not being created when I used one of the manual tiers options.
The program has been updated to better handle some errors that can occur (many still require program restart, but better inform you of what happened with dialogs).
It also now uses the FIRST pages directly for auto-team loading as the site I was using that provided the lists in XML is not going to be updated for this year’s events.
Installer still located here:
http://www.chiefdelphi.com/media/papers/2307
I have posted an updated version of the program at the CD-Media page listed in the previous post. If you have a version that does automatic team fetching, you can just grab the Update zip file and replace the main EXE with the one in the ZIP.
Changes:
  • CD Text automatically includes Code tags
  • File menu now includes a “Reload List” menu item which allows lists to be reloaded during the draft without restarting the program
  • The program no longer needs to be restarted when errors are encountered loading list files (not sure about other files yet).
Credit to rtfgnow for feature requests
As always, feature requests or bug reports are welcome via post, PM, email or IM
Can code-tags be in the settings somewhere? They’re not universally used among the current draft runners (and I don’t like them).
I mean, not that it’s a huge deal; I’m just nitpicking.
Sure!
I turned the autorun checkbox, which I never implemented anyway, into a checkbox to enable or disable the code tags.
Eric, Alex and I all use them and Ed doesn’t use the program so the default state of the checkbox is on.
Updated installer and update zips [strike]will be posted shortly.[/strike] are posted.
Ah, you’re right, my bad. Thanks!
No worries! Flexibility is always a good thing and it was pretty easy to implement.
Another thing. Can you implement a ‘copy text’ button.
