The Scoring system goes as follows:
20…1st seed
12…2nd and 3rd seed
6…4th through 8th
3…9th through 12th
2…12th through 16th
4…Quarter finalists
10…Semifinalists
20…Finalists
30…Winners
42…Chairmans
36…Engineering Inspiration Award
15…Rookie All-Star
10…Rooke Inspiration
8…Woodie Flowers
2…Win(s)
-2…Loss(es)
1…Tie(s)
8…Highest score / Highest Rookie Seed
5… Judges Award
2…for every non-placement award, except previously mentioned
This is the standard scoring for Fantasy First.
However, this is Vegas, so things will become interesting
You will have SEVEN selections. There will be 3 normal rounds + 4 Wild Card rounds. (Since this is Vegas, the gambling element has to come in.)
WC 1 = 2x points
WC 2 = 5x standard points
WC 3 = 10x standard points
WC 4 = 20x standard points
Unlike the other wildcard leagues, again because this is Vegas (and also because the regional is stacked), I am allowing you all to trade Wild Cards AT ANY POINT after the Wild Cards have been selected as long as
A) One of the other teams that you drafted isn’t your wildcard
B) WC 1 team is not the same as the WC 2 or WC 3 or WC 4 team (so, you if you draft 1902 as your WC1 team, you can’t draft
There are 50 Teams so, there will be 12 players (to best spread the wildcard picks around) with draft times (All times are Eastern.) And the draft order will be first-come first-serve (and will go from 12-1 in second and 1-12 in third).
Draft begins 2/27 at 5:00 PM and times are as follows for first 3 rounds
WC rounds will be noted by multipliers and will begin in 3 weeks to give players time to think about selections. Otherwise, players can trade in that 3-week period
…R1 R2 R3
- __________________ 5:00 PM 8:40(twice)
- ___________________ 5:10 8:30 8:50
- ___________________ 5:20 8:20 9:00
- ____________________5:30 8:10 9:10
- ____________________ 5:40 8:00 9:20
- ____________________ 5:50 7:50 9:30
- ____________________ 6:00 7:40 9:40
- ____________________ 6:10 7:30 9:50
- ____________________ 6:20 7:20 10:00
- ____________________6:30 7:10 10:10
- ___________________ 6:40 7:00 10:20
- ___________________6:50 (twice) 10:30
Just replace the underline with your name. (again, all times are eastern; so sign up ASAP)
