Field Dimensions
How far is the litter container from the alliance wall? I can’t find it anywhere.
It would be variable based on the size of the carpet.
2.2 ALLIANCE STATIONS
Red and Blue ALLIANCE STATIONS are located on each end of the FIELD, behind the ALLIANCE WALLS, and are bounded by the edges of the carpet, the ALLIANCE WALL, and White gaffers tape, which extends from the end of each GUARDRAIL to the edge of the carpet. The STARTING LINE is the width of the ALLIANCE STATION and is marked with 2 in. White gaffers tape that is 2 ft. 6 in. from the PLAYER STATIONS.
Each ALLIANCE STATION contains one (1) Bin which contains LITTER.
2.3.3 LITTER
Each LITTER is a solid core, green Pool Noodle, manufactured by Tundra (Part Number: SR20C). They are between 4 ft 7 in. and 4 ft. 11 in. in length and have an outside diameter of 2.6 in. Given that the manufacturing process for Pool Noodles is not tightly controlled and the Pool Noodles used and distributed for the 2015 season were made in different production runs, Teams should expect some variation in rigidity, length, diameter, and surface characteristics
Each ALLIANCE starts the MATCH with ten (10) LITTER, all of which are located in a white Bin. The LITTER is marked 1 in. from each end and in the middle with 2 in. “Red” and “Electric Blue” gaffers tape to match the ALLIANCE STATION in which it starts. The Bin is on the carpet and centered behind the middle PLAYER STATION such that back edge of the carpet is tangent to the Bin. The Bin is constructed from a US Plastics Tamco 30 Gallon Polyethylene Tank (Item #: 4031). It is 30.5 in. tall with a diameter of 17.75 in.
(emphasis mine)
What should it be usually?
Probably about what the Pedestal was last year. As I recall that was near the back edge of the carpet.
