Field Elements Shopping List
In the past, FIRST has put out a shopping list for the wood etc needed to build these field elements: Playing Field | FIRST
Since they aren’t doing that this year, has any team put one together? We are working on one but was curious if one was floating around. Thanks!
We ended up needing an additional 6 2x4s and didn’t use the 1/4-20s. The charging station does need the 1/4-20s though.
You’ll need to figure out what element(s) you’re building and then use the shopping list included in the documents. Here is an example for the CHARGE STATION.
OMG you’re a life saver! I couldn’t find this…where did you find it?
Thank you all for your help!
