I need the dimensions from the power port to the wall to get an auto program running, to grab the three balls in the trench during auto. but I cant get my math to work well.
I’m not exactly sure what dimension you’re talking about. Does this help?
I looked at that already. I need from the end of the power port to the edge of the field so I can mark where the wall would be.
If you’re talking about the power port to the left and right hand sides of the field, I’m not sure. If you could download the field CAD model, that’d probably be your best bet. If not, how accurate do you need it to be? I could probably find a pretty accurate dimension if it can be within two or three feet.
Does the cad model have to be downloaded to a computer with solid works or can I access it through something like github
I don’t know about Github, but Solidworks works. Alternatively, assuming the file is small enough, you could upload it to Onshape.
Ok thx I will try to see if I can use my dads computer to get the dimensions
