Field of view of an Axis USB camera
I’m currently working on an algorithm for tracking the high boiler and It would make my life so much easier if I knew what angle the top and bottom edges of an Axis USB camera make. Does anyone have this information? Thanks!
There is no such thing as an Axis USB camera - all Axis cameras stream MJPEG images over Ethernet. Can you specify which model camera you’re using?
I have never heard of an Axis USB camera are you sure that you aren’t confusing it with the Microsoft Lifecam HD-3000 Camera (am-3025) also what are you coding in?
USB? Also when you figure out the whole USB thing send the model #, there are many models of the Axis camera with varying viewing angles.
