Hey, I know I should feel really stupid about asking this, but the manual seemed unclear about it.
How high is the sensor on the minibot pole above the base?
If there is a resource I could use to find this information, that would be great as well.
Thanks!
Hallry
January 10, 2011, 8:22pm
Wolfgang:
Thanks!
As stated under section 2.2.5, The bottom of the lower disk (i.e. the portion of the TARGET contacted by the climbing MINIBOT) is approximately 122 inches above the floor. , and the circular base is 12 inches tall. Therefore, 122-12, meaning that there are 110 inches between the two. Correct? ::rtm::
EricH
3
The manual is quite clear. Section 2 gives the height as 122" above the floor.
You could also find the info in the field drawings.
Ctl-F is the typical way to access a PDF reader’s “find” feature, which may help find these.
(CD’s search feature is in the orange bar, if you suspect someone else has asked the same or a similar question.)
Thanks! That helps a lot! Didn’t see that in the manual.
