Im working on a website right now and i made a script in php to upload an image and then display it on a different page. It works very well. My only problem is that i want to be able to turn those images into thumbnails with small file sizes automatically once i upload the file to my server. I don’t really know that much php and i have no idea how i would accomplish this
I don’t know a lot about php either, but I think I saw somewhere that Photoshop has a utility included in it somewhere that allows you to create php galleries similar to Windows Explorer Filmstrip picture viewing… does your team have a copy of PS? Maybe other editors have this same feature (Paint Shop Pro, CoredDRAW, etc.)
Check those out.
yes we do have a copy of photoshop but i’ve never heard of a utility like that. But i also do not know much about photoshop
Download a copy of some forum software like Vbulletin, phpBB, or Invision, open it in Dreamweaver, and do a code search of the entire folder that you have to make into a site for “image resize” or “resize”.
you’ll want another library such as GD or ImageMagick to do the resizing. Googling those should give you plenty of material to get you started.
Could you just use something like Gallery?
If not, I’ve done some work on that, you can check this link:
http://users.wpi.edu/~woloi/pictures.txt
I haven’t looked at that since early summer, so I can’t say I know what I did, but if you can’t figure out what I did, I’d be more than happy to look back at it and help you. I believe the only problem should be mess and such, cause I never actually cleaned that code up.
Specifically, look at the following code, though it will need to be modified for your purposes:
function Thumbnails ($pics, $root, $thumbnails) {
#Pre: $pics is filled
#Post: Thumbnails are created for every new picture in directory
if ( !is_dir($thumbnails)) {
mkdir ($thumbnails);
chmod ($thumbnails, 0755);
else if (is_dir ($thumbnails)) {
for ($i = 0; $i < count($pics); $i++) {
if (!is_file($thumbnails . '/' . $pics$i])) {
exec ("convert $root/$pics$i] -resize 150x150 +profile '*' $thumbnails/$pics$i]");
chmod ("$thumbnails/$pics$i]", 0755);
Hope that helps.
In CPanel, does Fantastico have anything useful? (providing that you have CPanel and Fantastico)
You ran “convert”, so I assume you are using ImageMagick on your end, right?
Here is a snippet of code i wrote for an image gallery a while back. It has extensie debug statements that will give you som insight into its operation. It was adapted from some code i found in the PHP documentation. Note your server must have the GD library installed for this to work
function image_createThumb($src,$dest,$maxWidth,$maxHeight,$quality=100) {
print '$src = ' . $src . '<br>';
if (isset($dest)) {print '$dest is set<br>';} else {print '$dest is not set<br>';}
if (file_exists($src) && isset($dest)) {
print('JPEG Quality: ' . $quality .'<BR>');
// path info
$destInfo = pathInfo($dest);
// image src size
$srcSize = getImageSize($src);
// image dest size $destSize[0] = width, $destSize[1] = height
$srcRatio = $srcSize[0]/$srcSize[1]; // width/height ratio
$destRatio = $maxWidth/$maxHeight;
if ($destRatio > $srcRatio) {
$destSize[1] = $maxHeight;
$destSize[0] = $maxHeight*$srcRatio;
else {
$destSize[0] = $maxWidth;
$destSize[1] = $maxWidth/$srcRatio;
// path rectification
if ($destInfo'extension'] == "gif") {
$dest = substr_replace($dest, 'jpg', -3);
// true color image, with anti-aliasing
print '$maxHeight = ' . $maxHeight . '<br>';
print '$maxWidth = ' . $maxWidth . '<br>';
print 'src height = ' . $srcSize[1] . '<br>';
print 'src width = ' . $srcSize[0] . '<br>';
print 'dest height = ' . $destSize[1] . '<br>';
print 'dest width = ' . $destSize[0] . '<br>';
$destImage = imagecreatetruecolor($destSize[0],$destSize[1]);
imageAntiAlias($destImage,true);
// src image
switch ($srcSize[2]) {
case 1: //GIF
$srcImage = imageCreateFromGif($src);
break;
case 2: //JPEG
$srcImage = imageCreateFromJpeg($src);
break;
case 3: //PNG
$srcImage = imageCreateFromPng($src);
break;
default:
return false;
break;
// resampling
imageCopyResampled($destImage, $srcImage, 0, 0, 0, 0,$destSize[0],$destSize[1],$srcSize[0],$srcSize[1]);
// generating image
case 1:
case 2:
imageJpeg($destImage,$dest,$quality);
break;
case 3:
imagePng($destImage,$dest);
break;
return true;
else {
print 'file does not exist<br>';
return false;
Yes, I can’t remember why I picked ImageMagick, but it works, and it’s fairly easy to use.
