Still handled much better than at MSC last year. Still remember that the FTA blew on the fire at first, then it took 20 people half a minute to get a fire extinguisher around and blowing on the robot.
Regardless of any criticisms, props to the quick actions of the field staff this time around.
The electricity won’t hurt you. Your body resistance is extremely high, somewhere around 100kOhms. With some quick V=IR math, this only lets about 0.12mA of current through your body, which is barely anything. Sure, current can give you a hefty shock, but it’s the voltage that lets that current flow. That’s why you can comfortably stick your fingers in the anderson connector and not feel anything (assuming your skin is not wet, of course).
If there was a short by the chassis, (which there isn’t, as the robot lights are still functional), some heat would build up, but it’s nothing compared to the fire. The biggest thing to be careful of is the fire. The FTA did the right thing by grabbing the robot, hitting the e-stop and turning it on it’s side so the fire could be extinguished.
Please keep in mind that this only holds true for a body free of conductive items like wedding rings.
Don’t go poking around 6-gauge cables on a robot unless you’re bare-handed. Same rule holds true under the hood of your car. Having a ring pinned between a 12V source and a conductive frame will indeed hurt. Not restart-your-heart hurt, but certainly visit-the-ER hurt.
Judging by the fact that, despite my objections, members of my team regularly touch the positive and negative battery terminals at the same time, I’d say not much
Hi Al,
I’m looking forward to reading the full report.
In the meantime, based solely on the picture of the battery, I see no evidence that the carbon fiber conductivity could have caused this. There is no visual indication that the positive terminal had any serious heating. Only the negative terminal appears to be involved.
To me this indicates that the description of the negative terminal being jammed into the battery seems more likely the cause.
Either way, finding ways to prevent this from happening again is the best thing the FIRST community can do.
To be honest, I think the field crew did a pretty good job of extinguishing the fire, but everybody at the competition should know where the extinguishers are.
It wouldn’t be that hard to add a short explanation of where they are at the opening ceremonies.
XD. I’d be worried if the quickness of this field staff was quicker than the last fire.
They were about 45 seconds into march before they even e-stopped, which is where the clip that was posted in this thread, started.
There were not many fire incidents at FIRST events, that’s great and hope there won’t be any. Unfortunately there was at least one last year and already one this year. At every event they must keep couple of first extinguishers of different type, close to scoring table or a better place and all volunteers near the field should know the location. Same goes for pits. Also volunteers near field and those at pit admin must be trained/educated on which type of extinguisher is best for a situation. Since volunteers fron UL are always present at events, they could be the best to train, or anyone with fire depr can train. Fire incidents don’t happen, but when it happens there will be few hands to help.
OK,
So I have read explanations and I have seen photos that are not in this thread. I think everyone agrees that the battery was inserted up side down in the robot. So what likely occurred?
Our batteries are available in a about seven variations involving terminals. As such all variations start with a basic battery that has no terminal and a depression where the red and black epoxy filling is located. During manufacture, each terminal type is pressed down and soldered in place in this void and then the completed connection is filled with epoxy. When the battery was inserted up side down, extreme stress likely broke the internal connection on the negative terminal causing a high resistance connection. High resistance coupled with high current cause high temperature. So I believe, the terminal failure resulted in temperatures high enough to set the tape insulation on fire. From the picture of the battery above, the tape may have a paper base. Once ignition took place, other materials in the battery case also began to burn which resulted in the first picture. Notice the fire damage to the area surrounding the missing terminal. One of the pictures I saw still has the negative lead with the battery terminal still attached. Note that there is no swelling of the battery case (common with an internal short). It is possible that the battery was also shorting to the frame which produced the excessive current. Since there was no reported leakage and no swelling, I think the damage was primarily confined to the outside of the battery. It is also possible that wire terminal was not secure to the battery terminal which also results in a high resistance connection.
So a few things to take away from this incident…
Tight connections are essential in the high current paths of our robot electrical system. That means all crimps, all hardware must be tight. Tug on the wires, mover them around. If anything moves, correct it. We (Team 111) solder all crimps in this area and use #10 lock washers between the battery terminals and wire terminals on the battery. By adding washers between the terminals prevents them from sliding and loosening the retaining hardware. Do not lift the battery by the wires as this damages the internal battery connections made during manufacture. Train everyone on your pit crew on the proper method of handling your batteries (two hands please) and exactly how they should be installed in your robot. Check your batteries often for signs of having been dropped. A flat spot on a corner is a obvious sign or someone telling you that they dropped it is another. Recycle dropped batteries, they will fail under Al’s Einstein corollary to Murphy’s Law. Any robot item that can fail will fail on Einstein.
Watching the robot burn live, it looked like the bumper was also on fire.
According to this link it looks like a dry powder extinguisher was the way to go as it will extinguish a wood/plastic + electrical fire.
We were fortunate that the carpet and floor did not catch fire.
Electrically harming a person is a function of the current passed through the person and the path the current takes. Perhaps the most critical path is one crossing the body; either arm to arm or arm to leg.
While the resistance of skin, in good conditions is 100,000 kOhms or so, once the skin is penetrated the resistance drops significantly - Values ranging from 1000 Ohms to 500 Ohms.
Ventricular Fibrillation is probably the first effect to be concerned about. I see numbers as low as 30 mAmps, but those are associated with AC. That’s the magnitude level I have typically been instructed in. I see information indicating higher and lower levels of current at DC, but it probably depends upon the path!!
Electrically, the rules require the system to be isolated from chassis. The thing to realize is that in failure conditions, such as this, the chassis of the vehicle may no longer be isolated.
Even a fully charged battery should not be capable of doing harm, but under the precisely wrong conditions the current could become closer than you want to be!
They did a great job, but the response wasn’t quite as quick as it would appear from the video, which started a bit after the flames were noticed. The fire extinguisher was not at the scoring table – someone ran behind the bleachers to fetch it. (A fire extinguisher was prominently visible at fieldside near the head referee’s position for the rest of the event.)
The cause of the fire was due to the battery. The terminals came in contact with our carbon fiber baseplate, which is conductive. This caused it to create a circut and short causing the firebyou saw here. Thiscwas maimly because we attached our battery upside down which we encourage no one to mount their battery upsidemdown or against a conductive surface. Though, luckily nothing was damaged
After the batter was removed. The damage was minimal with only a burned spot on the carbon fiber base plate and the failure of one encoder. A decorative piece of poster board right next to the battery did not even get scorched. Not sure who ran for the extinguisher but he saved the bot. Here is a link to the battery long after the bot was up an running again.
That was our FTA Lorenzo who came in with the extingusher. We checked things out before handling the robot. The fire was relatively small when you were up close. The fire was mostly the insulation and the negative post area on the battery. FTA John was trying to not use the extinguisher if we could get away with it. They make a mess.
Had not had a fire in the PNW since 2010. The extinguisher usually lives in road case 8, which is normally right behind he FTA table. This was a double sided event, so case 8 was moved off field and the extinguisher was not placed well.
We have changed that for all future events. The extinguisher will live at the FTA table rather than case 8.
We use an ABC extinguisher on the recommendation of our friends at UL because the breadth of possible fire types is very wide.
JDL,
Your photo has a number of items I would like to address…
If your team is using this type of terminal, it should be turned towards the inside of the battery. Please note the snag hazard of hanging that retention screw over the side of the battery. Even covered in tape allows it to snag a chassis part and break the terminal off the battery.
The dicoloration of the copper is a good indicator of high temperature.
Note that the split washer appears to be mounted under the screw head not under the nut where it belongs.
The one good think is the wire sticking through the retention feature. This will help with keeping the wire in the connector. Frequently teams trim too little insulation and when tightening the screw will actually force the wire out of the connector.
For minimal cost, you can buy crimp on Burndy terminal from AndyMark and the crimper as well. A more reliable solution to this connector.
