Just a note for those who are trying to update their First libraries for EasyC. See this:
from here at bottom of page:
This is a fix for some data corruption problems occuring during interupt routines or something. Anyhow, EasyC doesn’t (I don’t think) have a way of specifying the file name for the FIRST library used for linking. The name of the NEW library is:
FRC_library_8722.lib
It replaces:
FRC_library.lib
This library is located (on my WindowsXP machine):
C:\Program Files\Intelitek\easyC for FRC\Frc\18F8722\FRC_library.lib
So, copy FRC_library_8722.lib to C:\Program Files\Intelitek\easyC for FRC\Frc\18F8722
Change the name of FRC_library.lib to FRC_library_old.lib
Change the name of FRC_library_8722.lib to FRC_library.lib
NOW you can recompile your code with the new library. This library change is only necessary for the new 2006 controllers (8722). There is no need to change the library for the 2005 controllers (8520).
I hope this doesn’t confuse anyone! I am thinking everyone should make sure and install this update, especially if you are using any of the sensors, including the camera.
