we are trying to wire the signal light to the digital sidecar, what connector do we use to wire it up?
Team 437
Team 437
we used one of the 2 wire jumper wires. all you do is cut one of the ends off run the posivive side to both La and Lb and the negative to N. then it plugs into the port right next to the power on the sidecar,
hope this is helpful. if you have anything else feel free to ask
