Our team is trying to do pathing in teleop, which has been working. But our problem is that our pose and odometry get messed up with wheel slippage and encoder misreadings. So we decided to get a limelight 3 and setup our home field with AprilTags. But I can not figure out how to “fix” our pose with the “megabotpose?” or whatever the limelight pose is called.
You will need to use a Pose Estimator, which will fuse the readings from your wheel encoders (odometry) and your vision measurements (limelight). Take a look through that page. Limelight docs also have a section about how to implement the Limelight data. I’m not sure how much experience you have with Limelight, so here is another helpful page about actually getting the data from the Limelight. This is a very basic answer that requires you to do some reading, so please feel free to ask more questions if you get stuck!
